[Swift-devel] Re: Memory in Swift
Justin M Wozniak wozniak at mcs.anl.gov
Mon Oct 18 13:21:45 CDT 2010
On Mon, 18 Oct 2010, Jonathan Monette wrote:
>    1) What is the maximum value for SWIFT_HEAP_MAX?  Is it the maximum
> memory available on the machine?  If I ask for 8Gb will the Java heap space
> be 8Gb?
In bin/swift, that value is passed directly to the Java VM, so it's
implementation-specific.  What kind of machine are you on?
>    2) Assuming that the above question does not fix my problem, what can
> be done to fix memory problems in Swift?  How should a Swift script be
> programmed to avoid these issues or is how Swift handles memory not
> optimal. I have a set of about 4100 images that will be stitched
> together to form a mosaic.  The size of this set is 8.1Gb.  Right now in
> my sites file I set SWIFT_HEAP_MAX to 4096M(4Gb) but I am still getting
> out of memory errors with the Java heap space.  Is Swift just not able
> to scale up to this size of data yet?
Justin M Wozniak
