[Swift-devel] Re: May need VOMS proxy for many OSG sites
    Arjun Comar
    mandaya at rose-hulman.edu
    Thu Jun 17 10:48:00 CDT 2010
Ah, I'll play with that then. Is the procedure for that documented on the
Engage VO site? And what does it mean if it's not added into Swift, that I
won't be able to run on sites that require it? Or does it operate like
grid-proxy-init in that once I apply it to a site, I'm good to go?
Arjun
On Thu, Jun 17, 2010 at 10:38 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Arjun, this may be the reason that your access to many OSG sites is
> failing.
> Find a site that fails using grid-proxy-init from say teraport.
> Then try that same site, using voms-proxy-init (sp?) on engage-login.
> We'll both need to dig into the full meaning of a "VOMS" proxy, but
> basically it appends extra "role" information to the proxy to indicate that
> you are activing as a member of a specific VO (in your case, the "engage"
> VO).
> I dont recall if we added that to Swift yet (I think not). Mihael, do you
> recal?
> If not, you'll need to do more of the initial testing from engage-login
> until we instal; OSG clients.
> - Mike
> ----- Forwarded Message -----
> From: "Brian Bockelman" <bbockelm at cse.unl.edu>
> To: "Robert Engel" <engel_r at ligo.caltech.edu>
> Cc: "Keith Chadwick" <chadwick at fnal.gov>, "Iwona Sakrejda" <
> isakrejda at lbl.gov>, OSG-int at opensciencegrid.org,
> OSG-VO-FORUM at opensciencegrid.org, "Arvind Gopu" <agopu at indiana.edu>, "Rob
> Quick" <rquick at iupui.edu>
> Sent: Thursday, June 17, 2010 2:44:16 AM GMT -06:00 US/Canada Central
> Subject: Re: How to know if a site requires a VOMS Proxy or a Grid Proxy
> for authentication?
> On Jun 17, 2010, at 12:39 AM, Robert Engel wrote:
> > Keith,
> >   thanks for the link. But that is what I meant by manually knocking on
> each door. As an OSG user I want a simple way to find out what proxy to use
> on each of the potential 50+ resources there are.
> Use a VOMS proxy.  Didn't we just determine they are a superset of grid
> proxies?  Reading through the thread, I didn't see any site saying "I accept
> grid proxies but not VOMS proxies."
> Ultimately, there are a million things that can go wrong in distributed
> computing (cosmic rays hitting fiber cables at FNAL).  Why concentrate on
> this one?  I'm not against having better probes or tests - but we have
> extremely limited effort.  I'd rather identify the areas where we need this
> the most.
> The only way to know if a site accepts your jobs are to submit jobs.  Why
> should we add central complexity instead of using auto-discovery (esp since
> the central view, whether MyOSG, BDII, etc, is always going to be wrong as
> they don't use your proxy)?
> We are a decentralized, distributed computing facility.  You can't have
> centralized information that's "correct" if you have a decentralized
> computing system.
> Brian
> > I am thinking that myOSG could provide the required proxy information for
> each of the resources. Perhaps Arvind and Rob can comment on that.
> > Robert
> > Keith Chadwick wrote:
> >> At 3:17 PM -0700 6/16/10, Robert Engel wrote:
> >>> Hey Iwona,
> >>>   currently I recommend in the documentation to always check with the
> membership VO if they support VOMS and provide a VOMS server. Just as you
> said, the VOMS proxy in the end is just a 'fancy' grid proxy and can be used
> as such. I recommend using the VOMS Proxy under this circumstances.
> >>> On the other hand I would like users who can't generate a VOMS Proxy
> with extended attributes to know if a certain site requires such without
> having to 'knock on every door' manually? Like for instance at Fermilab
> where this is required. I only know it is required because I talked to Burt.
> Otherwise I would have no idea.
> >> The requirement for voms proxies is explicitly published in the
> >> FermiGrid policy document:
> >>    http://fermigrid.fnal.gov/policy.html
> >> Direct quote from the above document:
> >>    VOs and VO members that desire to Fermilab grid resources must
> initialize
> >>    their credentials using:
> >>        * $VDT_LOCATION/voms/bin/voms-proxy-init
> >>    Those VOs and VO members that fail to use voms-proxy-init may be
> blocked
> >>    from accessing Fermilab grid resources.
> >> -Keith.
> >>> Thanks,
> >>> Robert
> >>> Iwona Sakrejda wrote:
> >>>> But even not all the sites that run GUMS servers requirer VOMS proxy.
> >>>> So I'd say - if a proxy is rejected by a site, is the error message
> clear? I never tried....
> >>>> Also the user should check with the VO. If a vo is utilizing
> functionality that comes with
> >>>> a VOMS proxy, it will be presumably educating its users about
> available roles and such, no?
> >>>> Always asking for a VOMS proxy is safer. If no VOMS server available -
> it will be reduced to
> >>>> a regular proxy. If a site is using map files, the extra stuff will be
> ignored and the proxy will
> >>>> work anyway.
> >>>> Isn't it so?
> >>>> Iwona
> >>>> On Wed, Jun 16, 2010 at 2:57 PM, Robert Engel <
> engel_r at ligo.caltech.edu <mailto:engel_r at ligo.caltech.edu>> wrote:
> >>>>    Steven,
> >>>>    ? Do you know how a user could find out what RSV probes are
> >>>>    running on any given site? I tried to find this in myOSG, but
> >>>>    nothing turned up.
> >>>>    Thanks,
> >>>>    Robert
> >>>>    Steven Timm wrote:
> >>>>        The answer is not always a clear yes or no. ?If a site copies
> >>>>        the OSG GUMS template and runs GUMS then they will end up
> >>>>        requiring voms proxies for about half of the VO's and not
> >>>>        for the other half.
> >>>>        You could indirectly find out by which RSV probes any given
> site
> >>>>        is running, GUMS sites run different RSV probes than
> grid-mapfile
> >>>>        sites do. ?by default all grid-mapfile sites do not require
> >>>>        any VOMS proxy.
> >>>>        FermiGrid is the only site I know of that requires VOMS proxy
> for
> >>>>        everyone and even we have a way to make exceptions if
> necessary.
> >>>>        Steve
> >>>>        On Wed, 16 Jun 2010, Robert Engel wrote:
> >>>>            Hello,
> >>>>            ?I am writing documentation for end users. I would like to
> >>>>            write how a user can find out if a site accepts a Grid
> >>>>            Proxy or requires a VOMS Proxy. Can that information be
> >>>>            found in myOSG?
> >>>>            Thanks,
> >>>>            Robert
> >>> Attachment converted: Macintosh HD:engel_r 18.vcf (TEXT/ttxt)
> (0040AFA0)
> > <engel_r.vcf>
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
Arjun Comar, Rose-Hulman '12
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100617/9092a99d/attachment.html>
