[Swift-devel] Re: May need VOMS proxy for many OSG sites
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Jun 17 11:37:06 CDT 2010
Arjun, one thing I should clarify: since I have not seen the errors you are getting, Im only suggesting that this *may* explain it, not that it *does*.
If not, please gather the errors you are getting for various grid operations and send them to swift-devel.
- Mike
----- "Arjun Comar" <mandaya at rose-hulman.edu> wrote:
> Ah, I'll play with that then. Is the procedure for that documented on
> the Engage VO site? And what does it mean if it's not added into
> Swift, that I won't be able to run on sites that require it? Or does
> it operate like grid-proxy-init in that once I apply it to a site, I'm
> good to go?
> Arjun
> On Thu, Jun 17, 2010 at 10:38 AM, Michael Wilde < wilde at mcs.anl.gov >
> wrote:
> Arjun, this may be the reason that your access to many OSG sites is
> failing.
> Find a site that fails using grid-proxy-init from say teraport.
> Then try that same site, using voms-proxy-init (sp?) on engage-login.
> We'll both need to dig into the full meaning of a "VOMS" proxy, but
> basically it appends extra "role" information to the proxy to indicate
> that you are activing as a member of a specific VO (in your case, the
> "engage" VO).
> I dont recall if we added that to Swift yet (I think not). Mihael, do
> you recal?
> If not, you'll need to do more of the initial testing from
> engage-login until we instal; OSG clients.
> - Mike
> ----- Forwarded Message -----
> From: "Brian Bockelman" < bbockelm at cse.unl.edu >
> To: "Robert Engel" < engel_r at ligo.caltech.edu >
> Cc: "Keith Chadwick" < chadwick at fnal.gov >, "Iwona Sakrejda" <
> isakrejda at lbl.gov >, OSG-int at opensciencegrid.org ,
> OSG-VO-FORUM at opensciencegrid.org , "Arvind Gopu" < agopu at indiana.edu
> >, "Rob Quick" < rquick at iupui.edu >
> Sent: Thursday, June 17, 2010 2:44:16 AM GMT -06:00 US/Canada Central
> Subject: Re: How to know if a site requires a VOMS Proxy or a Grid
> Proxy for authentication?
> On Jun 17, 2010, at 12:39 AM, Robert Engel wrote:
> > Keith,
> > thanks for the link. But that is what I meant by manually knocking
> on each door. As an OSG user I want a simple way to find out what
> proxy to use on each of the potential 50+ resources there are.
> Use a VOMS proxy. Didn't we just determine they are a superset of grid
> proxies? Reading through the thread, I didn't see any site saying "I
> accept grid proxies but not VOMS proxies."
> Ultimately, there are a million things that can go wrong in
> distributed computing (cosmic rays hitting fiber cables at FNAL). Why
> concentrate on this one? I'm not against having better probes or tests
> - but we have extremely limited effort. I'd rather identify the areas
> where we need this the most.
> The only way to know if a site accepts your jobs are to submit jobs.
> Why should we add central complexity instead of using auto-discovery
> (esp since the central view, whether MyOSG, BDII, etc, is always going
> to be wrong as they don't use your proxy)?
> We are a decentralized, distributed computing facility. You can't have
> centralized information that's "correct" if you have a decentralized
> computing system.
> Brian
> > I am thinking that myOSG could provide the required proxy
> information for each of the resources. Perhaps Arvind and Rob can
> comment on that.
> > Robert
> > Keith Chadwick wrote:
> >> At 3:17 PM -0700 6/16/10, Robert Engel wrote:
> >>> Hey Iwona,
> >>> currently I recommend in the documentation to always check with
> the membership VO if they support VOMS and provide a VOMS server. Just
> as you said, the VOMS proxy in the end is just a 'fancy' grid proxy
> and can be used as such. I recommend using the VOMS Proxy under this
> circumstances.
> >>> On the other hand I would like users who can't generate a VOMS
> Proxy with extended attributes to know if a certain site requires such
> without having to 'knock on every door' manually? Like for instance at
> Fermilab where this is required. I only know it is required because I
> talked to Burt. Otherwise I would have no idea.
> >> The requirement for voms proxies is explicitly published in the
> >> FermiGrid policy document:
> >> http://fermigrid.fnal.gov/policy.html
> >> Direct quote from the above document:
> >> VOs and VO members that desire to Fermilab grid resources must
> initialize
> >> their credentials using:
> >> * $VDT_LOCATION/voms/bin/voms-proxy-init
> >> Those VOs and VO members that fail to use voms-proxy-init may be
> blocked
> >> from accessing Fermilab grid resources.
> >> -Keith.
> >>> Thanks,
> >>> Robert
> >>> Iwona Sakrejda wrote:
> >>>> But even not all the sites that run GUMS servers requirer VOMS
> proxy.
> >>>> So I'd say - if a proxy is rejected by a site, is the error
> message clear? I never tried....
> >>>> Also the user should check with the VO. If a vo is utilizing
> functionality that comes with
> >>>> a VOMS proxy, it will be presumably educating its users about
> available roles and such, no?
> >>>> Always asking for a VOMS proxy is safer. If no VOMS server
> available - it will be reduced to
> >>>> a regular proxy. If a site is using map files, the extra stuff
> will be ignored and the proxy will
> >>>> work anyway.
> >>>> Isn't it so?
> >>>> Iwona
> >>>> On Wed, Jun 16, 2010 at 2:57 PM, Robert Engel <
> engel_r at ligo.caltech.edu <mailto: engel_r at ligo.caltech.edu >> wrote:
> >>>> Steven,
> >>>> ? Do you know how a user could find out what RSV probes are
> >>>> running on any given site? I tried to find this in myOSG, but
> >>>> nothing turned up.
> >>>> Thanks,
> >>>> Robert
> >>>> Steven Timm wrote:
> >>>> The answer is not always a clear yes or no. ?If a site copies
> >>>> the OSG GUMS template and runs GUMS then they will end up
> >>>> requiring voms proxies for about half of the VO's and not
> >>>> for the other half.
> >>>> You could indirectly find out by which RSV probes any given site
> >>>> is running, GUMS sites run different RSV probes than grid-mapfile
> >>>> sites do. ?by default all grid-mapfile sites do not require
> >>>> any VOMS proxy.
> >>>> FermiGrid is the only site I know of that requires VOMS proxy for
> >>>> everyone and even we have a way to make exceptions if necessary.
> >>>> Steve
> >>>> On Wed, 16 Jun 2010, Robert Engel wrote:
> >>>> Hello,
> >>>> ?I am writing documentation for end users. I would like to
> >>>> write how a user can find out if a site accepts a Grid
> >>>> Proxy or requires a VOMS Proxy. Can that information be
> >>>> found in myOSG?
> >>>> Thanks,
> >>>> Robert
> >>> Attachment converted: Macintosh HD:engel_r 18.vcf (TEXT/ttxt)
> (0040AFA0)
> > <engel_r.vcf>
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
> Arjun Comar, Rose-Hulman '12
Michael Wilde
