[Swift-devel] Re: Start up exercises
    Arjun Comar
    mandaya at rose-hulman.edu
    Wed Jun  9 18:37:42 CDT 2010
Good news everyone! I got the teraport configurations working, so I added
single site profiles for teraport and two multisite profiles. I'm still
learning gridftp, etc., so I don't have any working OSG profiles yet. I've
tested everything, so they should all work, but let me know if you have any
problems. The tc.data file from my last email should work fine.
Arjun
On Wed, Jun 9, 2010 at 5:45 PM, Arjun Comar <mandaya at rose-hulman.edu> wrote:
> Alright, here they are. I'll send out the teraport configurations once I
> figure them out. I'm including my tc.data file so that you don't have to sit
> around messing with that. Make sure to change the workdirectory tag in each
> sites.xml file appropriately. And for the last profile (profile_4, remote
> ssh to coasters+pbs on pads) make sure to grid-proxy-init on both bridled
> (or whatever other machine you're running from) and on pads (its configured
> to run on login1 so use that). Let me know if you need any more help.
> Arjun
> On Wed, Jun 9, 2010 at 5:12 PM, Arjun Comar <mandaya at rose-hulman.edu>wrote:
>> Sure, give me a few minutes to separate out and test my profiles. I have
>> local pbs, local pbs /w coasters, remote via ssh to pbs + coasters (single
>> machine), and remote via ssh (single machine). I'm still working on getting
>> multiple machines working (because I'm getting an exception trying to run
>> swift + coasters on teraport, and I'm trying to figure out why. I've tracked
>> it to a message in a log file that's complaining about certificates, but
>> those seem in order).
>> Arjun
>> On Wed, Jun 9, 2010 at 10:19 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>>> David and Arjun, can you pool the configurations and procedures you used
>>> for the following initial learning exercises, and work to get them into a
>>> form where Dennis, Jon, and Thiago can use them, and in doing so, test them
>>> as general tutorial exercises?
>>> - local multicore (done by David; should add info on throttling)
>>> - ssh to multiple multicore hosts
>>> - local pbs
>>> - local pbs w/ coasters
>>> - ssh to multiple pbs-coasters
>>> These would be the first of the "profiles" we discussed on yesterday's
>>> conf call.
>>> - Mike
>>> ----- "Michael Wilde" <wilde at mcs.anl.gov> wrote:
>>> > Hi All,
>>> > As you go through your start-up exercises, you should build Swift from
>>> > source and use the stable branch. You'll find that running on multiple
>>> > clusters over ssh to coasters with PBS (eg to run from bridled to PADS
>>> > and TeraPort) only works in the stable branch.
>>> > Ive been pointing some of you to my modified stable branch:
>>> >   /home/wilde/swift/src/stable/cog/modules/swift/dist/swift-svn/bin
>>> > (put that at the front of your PATH)
>>> > This build has a few other fixes and some useful default properties.
>>> > In the coming weeks we'll work to get these fixes out into either
>>> > trunk and/or stable.
>>> > - Mike
>>> Michael Wilde
>>> Computation Institute, University of Chicago
>>> Mathematics and Computer Science Division
>>> Argonne National Laboratory
>> Arjun Comar, Rose-Hulman '12
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100609/8c3f9467/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100609/8c3f9467/attachment.zip>
