[Swift-devel] Re: Start up exercises
    Arjun Comar
    mandaya at rose-hulman.edu
    Wed Jun  9 17:12:22 CDT 2010
Sure, give me a few minutes to separate out and test my profiles. I have
local pbs, local pbs /w coasters, remote via ssh to pbs + coasters (single
machine), and remote via ssh (single machine). I'm still working on getting
multiple machines working (because I'm getting an exception trying to run
swift + coasters on teraport, and I'm trying to figure out why. I've tracked
it to a message in a log file that's complaining about certificates, but
those seem in order).
Arjun
On Wed, Jun 9, 2010 at 10:19 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> David and Arjun, can you pool the configurations and procedures you used
> for the following initial learning exercises, and work to get them into a
> form where Dennis, Jon, and Thiago can use them, and in doing so, test them
> as general tutorial exercises?
> - local multicore (done by David; should add info on throttling)
> - ssh to multiple multicore hosts
> - local pbs
> - local pbs w/ coasters
> - ssh to multiple pbs-coasters
> These would be the first of the "profiles" we discussed on yesterday's conf
> call.
> - Mike
> ----- "Michael Wilde" <wilde at mcs.anl.gov> wrote:
> > Hi All,
> > As you go through your start-up exercises, you should build Swift from
> > source and use the stable branch. You'll find that running on multiple
> > clusters over ssh to coasters with PBS (eg to run from bridled to PADS
> > and TeraPort) only works in the stable branch.
> > Ive been pointing some of you to my modified stable branch:
> >   /home/wilde/swift/src/stable/cog/modules/swift/dist/swift-svn/bin
> > (put that at the front of your PATH)
> > This build has a few other fixes and some useful default properties.
> > In the coming weeks we'll work to get these fixes out into either
> > trunk and/or stable.
> > - Mike
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
Arjun Comar, Rose-Hulman '12
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100609/05c080a0/attachment.html>
