[Swift-devel] Start up exercises
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Jun  9 10:19:08 CDT 2010
David and Arjun, can you pool the configurations and procedures you used for the following initial learning exercises, and work to get them into a form where Dennis, Jon, and Thiago can use them, and in doing so, test them as general tutorial exercises?
- local multicore (done by David; should add info on throttling)
- ssh to multiple multicore hosts
- local pbs
- local pbs w/ coasters
- ssh to multiple pbs-coasters
These would be the first of the "profiles" we discussed on yesterday's conf call.
- Mike
----- "Michael Wilde" <wilde at mcs.anl.gov> wrote:
> Hi All,
> As you go through your start-up exercises, you should build Swift from
> source and use the stable branch. You'll find that running on multiple
> clusters over ssh to coasters with PBS (eg to run from bridled to PADS
> and TeraPort) only works in the stable branch.
> Ive been pointing some of you to my modified stable branch:
>   /home/wilde/swift/src/stable/cog/modules/swift/dist/swift-svn/bin
> (put that at the front of your PATH)
> This build has a few other fixes and some useful default properties.
> In the coming weeks we'll work to get these fixes out into either
> trunk and/or stable.
> - Mike
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
