[Swift-devel] Re: [Swift-user] Error using programs in swift
    Mark Maienschein-Cline
    mmaiensc at uchicago.edu
    Fri Feb 12 20:19:21 CST 2010
Here is the log file and the Swift script for the java
NullPointerError I have been getting. Le me know if you also need the
code for the application. I am running swift locally on the cluster
sisboombah.uchicago.edu.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100212/094ad2bd/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100212/094ad2bd/attachment-0001.obj>
On Feb 12, 2010, at 5:47 PM, Michael Wilde wrote:
> Mark, a null ptr exception is always an internal Swift error
> triggered by some problem in Java.
> Please send to swift-devel#ci.uchicago.edu the Swift script and the
> Swift log file from the run (the one called some-long-name.log) -
> or tell us where we can find it on the CI network.
> Thanks,
> Mike
> ----- "Mark Maienschein-Cline" <mmaiensc at uchicago.edu> wrote:
>> Hi,
>> I'm getting a "java.lang.NullPointerException" error when I call some
>> of my programs (written in C) in Swift (in the local mode). The
>> programs work correctly when I run them from the command line, and I
>> don't think there is any error in the parameters swift is passing to
>> the program. Does anyone know what problems can cause this kind of
>> error?
>> Thanks,
>> Mark_______________________________________________
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
