[Swift-devel] Re: [Swift-user] Error using programs in swift
wilde at mcs.anl.gov wilde at mcs.anl.gov
Mon Feb 15 22:19:23 CST 2010
Mark, the problem looks to me like Swift is not handing the following programming error correctly.
In the line:
   subpeaks @file1 @file2 @max_dist stdout=@output;
you dont want to put the @ on the int max_dist.
Remember, @ is shorthand for the @filename(), and you can't apply that to an int.
I *think* Swift should generate a compile-time type violation, but thats perhaps not do-able at the moment for @func() primitives, which have some type flexibility.
So the short answer is: take off the @ on max_dist. When you list a scalar variable in an app() command-line prototype, the scalar's value is placed on the command line.
- Mike
----- "Mark Maienschein-Cline" <mmaiensc at uchicago.edu> wrote:
> Hi,
> Here is the log file and the Swift script for the java
> NullPointerError I have been getting. Le me know if you also need the
> code for the application. I am running swift locally on the cluster
> sisboombah.uchicago.edu.
> Thanks,
> Mark
> On Feb 12, 2010, at 5:47 PM, Michael Wilde wrote:
> > Mark, a null ptr exception is always an internal Swift error
> > triggered by some problem in Java.
> > Please send to swift-devel#ci.uchicago.edu the Swift script and the
> > Swift log file from the run (the one called some-long-name.log) -
> > or tell us where we can find it on the CI network.
> > Thanks,
> > Mike
> >> Hi,
> >> I'm getting a "java.lang.NullPointerException" error when I call
> some
> >> of my programs (written in C) in Swift (in the local mode). The
> >> programs work correctly when I run them from the command line, and
> I
> >> don't think there is any error in the parameters swift is passing
> to
> >> the program. Does anyone know what problems can cause this kind of
> >> error?
> >> Thanks,
> >> Mark_______________________________________________
> >> Swift-user mailing list
> >> Swift-user at ci.uchicago.edu
> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
