[Swift-devel] how to comment out brackets
    skenny at uchicago.edu
    Tue Feb  9 20:32:28 CST 2010
>On Tue, 2010-02-09 at 18:13 -0600, skenny at uchicago.edu wrote:
>> does anyone know if there's a way i can comment out a bracket
>> in a swift string?
>> for example something like this:
>> string cmdstr = "\{";
>> trace(cmdstr);
>> produces:
>> Could not compile SwiftScript source: line 15:27: unexpected
>> char: '{'
>> not sure if it's a bug or i'm just missing something really
>> simple here :)
>You shouldn't need to escape them (and the swift parser probably
>complains because it doesn't recognize the escape sequence),
but I have
>a suspicion you're sending this email because you had a
problem, and I
>suspect that problem is that the swift compiler passes brackets
>unescaped to karajan, in which the bracket means something.
>If that's the case, try "{{" to generate one bracket. You
don't need to
>escape the closing bracket (i.e. "}").
that did it, thanks! double open-bracket gets it thru (yeah, i
had tried not escaping it at all and needless to say it
produced an error as well).
