[Swift-devel] Format of site tests
Michael Wilde wilde at mcs.anl.gov
Fri Dec 10 14:20:28 CST 2010
Does that work well for site testing, where each test will likely change subset of config settings? I assume any test script could also opt to provide its own config files as in the example I posted?
If you can specify a style, Justin, then Sarah and the rest of us can develop and run tests, and then plug them into the framework.
- Mike
----- Original Message -----
> In the new nightly.sh, each test group has an associated set of
> configuration file templates that is lightly processed by sed.
> On Fri, 10 Dec 2010, Michael Wilde wrote:
> > Sarah,
> > Justin and I use a format for site testing that is roughly as shown
> > below: a single script that emits swift.property settings, tc,
> > sites.xml, the swift script.
> > It can and should create any input data and external mappers as
> > needed.
> > I hope this helps you get started creating and running these tests.
> > You
> > and Justin should schedule a call to discuss how to integrate these
> > tests into the test suite.
> > This will take some discussion, which we should do on this list, but
> > hopefully this is a good starting point for the site tests.
> > I think Ben has something similar in the existing tests, but I have
> > not
> > looked at those yet.
> > - Mike
> > [mwilde at master tests]$ cat t1.sh
> > cat >tc <<EOF
> > sge cat /bin/cat null null null
> > EOF
> > cat >sites.xml <<EOF
> > <config>
> >  <pool handle="sge">
> >    <execution provider="sge" url="none" />
> >    <profile namespace="globus" key="pe">shm</profile>
> >    <profile namespace="globus" key="maxwalltime">00:01:00</profile>
> >    <profile namespace="karajan" key="initialScore">10000</profile>
> >    <profile namespace="karajan" key="jobThrottle">.20</profile>
> >    <filesystem provider="local" />
> >    <workdirectory>$PWD</workdirectory>
> >  </pool>
> > </config>
> > EOF
> > cat >cf <<EOF
> > wrapperlog.always.transfer=true
> > sitedir.keep=true
> > execution.retries=0
> > lazy.errors=false
> > status.mode=provider
> > use.provider.staging=false
> > provider.staging.pin.swiftfiles=false
> > EOF
> > cat >catsn.swift <<EOF
> > type file;
> > app (file o) cat (file i)
> >  cat @i stdout=@o;
> > file out[]<simple_mapper; location="outdir",
> > prefix="f.",suffix=".out">;
> > foreach j in [1:@toint(@arg("n","1"))] {
> >  file data<"data.txt">;
> >  out[j] = cat(data);
> > EOF
> > echo Hi There Swift! >data.txt
> > swift -config cf -tc.file tc -sites.file sites.xml catsn.swift
> > -n=100
> Justin M Wozniak
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
