[Swift-devel] Format of site tests
Justin M Wozniak
wozniak at mcs.anl.gov
Fri Dec 10 12:40:00 CST 2010
In the new nightly.sh, each test group has an associated set of
configuration file templates that is lightly processed by sed.
On Fri, 10 Dec 2010, Michael Wilde wrote:
> Sarah,
> Justin and I use a format for site testing that is roughly as shown
> below: a single script that emits swift.property settings, tc,
> sites.xml, the swift script.
> It can and should create any input data and external mappers as needed.
> I hope this helps you get started creating and running these tests. You
> and Justin should schedule a call to discuss how to integrate these
> tests into the test suite.
> This will take some discussion, which we should do on this list, but
> hopefully this is a good starting point for the site tests.
> I think Ben has something similar in the existing tests, but I have not
> looked at those yet.
> - Mike
> [mwilde at master tests]$ cat t1.sh
> cat >tc <<EOF
> sge cat /bin/cat null null null
> EOF
> cat >sites.xml <<EOF
> <config>
> <pool handle="sge">
> <execution provider="sge" url="none" />
> <profile namespace="globus" key="pe">shm</profile>
> <profile namespace="globus" key="maxwalltime">00:01:00</profile>
> <profile namespace="karajan" key="initialScore">10000</profile>
> <profile namespace="karajan" key="jobThrottle">.20</profile>
> <filesystem provider="local" />
> <workdirectory>$PWD</workdirectory>
> </pool>
> </config>
> EOF
> cat >cf <<EOF
> wrapperlog.always.transfer=true
> sitedir.keep=true
> execution.retries=0
> lazy.errors=false
> status.mode=provider
> use.provider.staging=false
> provider.staging.pin.swiftfiles=false
> EOF
> cat >catsn.swift <<EOF
> type file;
> app (file o) cat (file i)
> cat @i stdout=@o;
> file out[]<simple_mapper; location="outdir", prefix="f.",suffix=".out">;
> foreach j in [1:@toint(@arg("n","1"))] {
> file data<"data.txt">;
> out[j] = cat(data);
> EOF
> echo Hi There Swift! >data.txt
> swift -config cf -tc.file tc -sites.file sites.xml catsn.swift -n=100
Justin M Wozniak
