[Swift-devel] Re: Hacking swift/karajan to fetch a job description
Zhao Zhang
zhaozhang at uchicago.edu
Thu Aug 26 14:51:12 CDT 2010
Mihael Hategan wrote:
> On Thu, 2010-08-26 at 14:25 -0500, Zhao Zhang wrote:
>> Hi, Mihael
>> I am wondering where I can get the job description? I was trying to hack
>> the _swiftwrap and disable file transfer in order to minimize the workload.
>> Is there any way for me to do this while running with dryrun option of
>> swift? Thanks.
> That seems to overlap with CDM. Can you be more exact about what you are
> trying to do?
I am trying to use swift dryrun as a compiler to compile swift script to
a job list, so I could run with the
system I implemented on BG/P.
best
zhao
> Justin has some ifs in vdl-int.k that can disable staging for select
> files. Things are a bit different if you use provider staging. You can
> also get the task object and that will contain the JobSpecification
> which has all the arguments.
> Mihael
