[Swift-devel] Re: Need help on race issue in Swift on Montage code
    Jonathan Monette
    jon.monette at gmail.com
    Thu Aug 26 14:48:20 CDT 2010
trunk r3566.
Attached is a tarball of the source files I used along with the screen
output of a run that failed and one that completed.
On 08/26/2010 02:44 PM, Mihael Hategan wrote:
> On Thu, 2010-08-26 at 14:06 -0500, Jonathan Monette wrote:
>> If looking at log files or output files will help to give a better idea
>> of the problem, you can take a look at
>> ~jonmon/Workspace/Swift/Montage/m101_j_05x05.  This is my 18 image set.
>> In that directory there is two run directories.  run.0002 is a run that
>> completed the workflow and run.0001 is a run that hung.  In each of
>> those directories there is a swift.out file that contains the output to
>> the screen that was captured.
>> Also, Mihael when the hang occurs, I type v for the inhook you set up
>> and I get
>> Register Futures:
>> and then nothing.  Does this mean there is no listeners set up and that
>> is why it hung?
> The first part. I'm not sure about the second.
> Send me the scripts, and I'll try to reproduce it. Can you tell me the
> exact svn version of swift?
> Mihael
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100826/e1f2e07e/attachment.bin>
