[Swift-devel] Re: Need help on race issue in Swift on Montage code
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Aug 26 14:44:59 CDT 2010
On Thu, 2010-08-26 at 14:06 -0500, Jonathan Monette wrote:
> If looking at log files or output files will help to give a better idea
> of the problem, you can take a look at
> ~jonmon/Workspace/Swift/Montage/m101_j_05x05.  This is my 18 image set.
> In that directory there is two run directories.  run.0002 is a run that
> completed the workflow and run.0001 is a run that hung.  In each of
> those directories there is a swift.out file that contains the output to
> the screen that was captured.
> Also, Mihael when the hang occurs, I type v for the inhook you set up
> and I get
> Register Futures:
> and then nothing.  Does this mean there is no listeners set up and that
> is why it hung?
The first part. I'm not sure about the second.
Send me the scripts, and I'll try to reproduce it. Can you tell me the
exact svn version of swift?
Mihael
