[Swift-devel] process hogging memory on ranger login
Mihael Hategan
hategan at mcs.anl.gov
Sat Nov 21 13:22:13 CST 2009
On Fri, 2009-11-20 at 13:01 -0600, skenny at uchicago.edu wrote:
> so, using the latest swift (swift-r3116 cog-r2482) i submitted
> a 1,179,647-job workflow to ranger...got this far:
> Progress: Submitted:16378 Active:1 Finished successfully:412482
> was in that state for a while (~24hrs) showing this in the queue:
> 1143906 data tg457040 Waiting 2944 01:10:00
> Thu Nov 19 07:22:48
Logs would help.
> which seemed relatively normal (a job requesting that many
> cores on ranger can sometimes be in the queue for quite some
> time). however, i then got an email from tacc:
> I have noticed that you have a java process running on Ranger
> (login3). The process is consuming quite some resources.
Please ask them to be more specific. If it was consuming virtual memory,
then that's a non-issue. If it was consuming lots of CPU than that's a
problem.
> Since
> it is running already for over a day, I assume that this is a
> run-away process that is left over from something you did
> earlier.
> so, i killed the process on the login, but i wasn't sure what
> to make of it...the job remains in the queue...i wonder if
> it's ok to try a resume on this workflow or if that might
> spawn another such process on the login (?)
It will spawn another such process on the login. That's the coaster
service.
