[Swift-devel] process hogging memory on ranger login
skenny at uchicago.edu
Fri Nov 20 15:10:34 CST 2009
>so, using the latest swift (swift-r3116 cog-r2482) i submitted
>a 1,179,647-job workflow to ranger
sorry, my mistake, i just realized that is NOT the latest
cog/swift (despite having been recently compiled)...i'll try a
resume with the latest code and see if the problem persists...
>Progress: Submitted:16378 Active:1 Finished
successfully:412482
>was in that state for a while (~24hrs) showing this in the queue:
>1143906 data tg457040 Waiting 2944 01:10:00
>Thu Nov 19 07:22:48
>which seemed relatively normal (a job requesting that many
>cores on ranger can sometimes be in the queue for quite some
>time). however, i then got an email from tacc:
>I have noticed that you have a java process running on Ranger
>(login3). The process is consuming quite some resources. Since
>it is running already for over a day, I assume that this is a
>run-away process that is left over from something you did
>earlier.
>so, i killed the process on the login, but i wasn't sure what
>to make of it...the job remains in the queue...i wonder if
>it's ok to try a resume on this workflow or if that might
>spawn another such process on the login (?)
>_______________________________________________
>Swift-devel mailing list
>Swift-devel at ci.uchicago.edu
>http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
