[Swift-devel] Issues with dependency completion
Mihael Hategan hategan at mcs.anl.gov
Fri Nov 13 12:45:09 CST 2009
The connection time-out would suggest that something isn't right with
the network config. Usual suspects are NAT not working or a missing
GLOBUS_HOSTNAME.
Btw, in order to avoid setting GLOBUS_HOSTNAME every time, you could put
it in sites.xml as this:
<profile namespace="globus"
key="internalHostname">172.17.5.144</profile>
On Fri, 2009-11-13 at 11:42 -0600, Justin M Wozniak wrote:
> I'm currently getting some new errors in my swift output (for the PTMap
> workflow).  Might be related to what Mike was seeing.  I have replication
> off, zeptoos on.  I'm going to keep looking for what the problem might be
> but I thought I should post that I'm seeing something similar.
> Progress:  Submitted:10  Finished successfully:16
> Worker task failed: 1113-451015-000000Block task ended prematurely
> Statement unlikely to be reached at
> /home/wozniak/.globus/coasters/cscript31418.pl line 592.
>          (Maybe you meant system() when you said exec()?)
> Failed to connect: Connection timed out at
> /home/wozniak/.globus/coasters/cscript31418.pl line 129.
