[Swift-devel] Issues with dependency completion
Justin M Wozniak wozniak at mcs.anl.gov
Fri Nov 13 13:32:44 CST 2009
That was it. oops
On Fri, 13 Nov 2009, Mihael Hategan wrote:
> The connection time-out would suggest that something isn't right with
> the network config. Usual suspects are NAT not working or a missing
> GLOBUS_HOSTNAME.
> Btw, in order to avoid setting GLOBUS_HOSTNAME every time, you could put
> it in sites.xml as this:
> <profile namespace="globus"
> key="internalHostname">172.17.5.144</profile>
> On Fri, 2009-11-13 at 11:42 -0600, Justin M Wozniak wrote:
>> I'm currently getting some new errors in my swift output (for the PTMap
>> workflow).  Might be related to what Mike was seeing.  I have replication
>> off, zeptoos on.  I'm going to keep looking for what the problem might be
>> but I thought I should post that I'm seeing something similar.
Justin M Wozniak
