[Swift-devel] Issues with dependency completion
Justin M Wozniak wozniak at mcs.anl.gov
Fri Nov 13 11:42:36 CST 2009
I'm currently getting some new errors in my swift output (for the PTMap
workflow).  Might be related to what Mike was seeing.  I have replication
off, zeptoos on.  I'm going to keep looking for what the problem might be
but I thought I should post that I'm seeing something similar.
Progress:  Submitted:10  Finished successfully:16
Worker task failed: 1113-451015-000000Block task ended prematurely
Statement unlikely to be reached at
/home/wozniak/.globus/coasters/cscript31418.pl line 592.
         (Maybe you meant system() when you said exec()?)
Failed to connect: Connection timed out at
/home/wozniak/.globus/coasters/cscript31418.pl line 129.
Justin M Wozniak
