[Fwd: Re: [Swift-devel] Problems with Swift trunk on abe]
Mihael Hategan
hategan at mcs.anl.gov
Tue Nov 3 11:05:23 CST 2009
Thanks. I'm looking into it.
On Tue, 2009-11-03 at 10:19 -0600, Michael Wilde wrote:
> Similar problems happen on Ranger. I used an older Swift build
> initially, and it ran.
> Then I updated to the latest, and I get the following similar failure:
> RunID: 20091103-1016-khfn59yf
> Progress:
> Ex098
> java.lang.NullPointerException
> at
> org.globus.cog.karajan.workflow.nodes.functions.Variable.function(Variable.java:38)
> at
> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:45)
> at
> org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:51)
> edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:643)
> at
> edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:668)
> at java.lang.Thread.run(Thread.java:619)
> Execution failed:
> Argument size mismatch. Got 1 names and 2 values
> login3$
> Im going try the bgp next. If it works there, we can leave this issue
> for after SC. Else, I'll need to resolve it.
> - Mike
> -------- Original Message --------
> Subject: Re: [Swift-devel] Problems with Swift trunk on abe
> Date: Tue, 03 Nov 2009 08:18:55 -0600
> From: Michael Wilde <wilde at mcs.anl.gov>
> To: swift-devel <swift-devel at ci.uchicago.edu>
> References: <4AF03842.70300 at mcs.anl.gov>
> Using the Swift build (and swift.properties) that works on communicado,
> I still get the same failures on Abe.
> I'm going to try a few other systems to see if the problem is widespread
> or local to Abe.
> - Mike
> On 11/3/09 8:03 AM, Michael Wilde wrote:
> > What seems like the a build of the same Swift & CoG svn revision is
> > working on communicado but giving strange and transient results on Abe.
> > A series of 5 runs of the same code (with .xml and .kml files left in
> > place) give the set of errors below.
> > I will try to use the release build on communicado, to see if this is
> > being caused by some Java compiler difference on Abe.
> > Suggestions welcome. Mihael, I can get you the logs - they are on abe in
> > ~wilde/run.58, along with the source: psim.basicex1.swift
> > - Mike
> > Output with a few progress and blank lines removed:
> > (full output is in: http://www.ci.uchicago.edu/~wilde/abe.swiftproblem.txt )
> > honest4$ ls
> > Protein.map* Protein.map~* etc input@ logs/ psim.basicex1.swift*
> > sites.xml t.swift* t.swift~* tc tc~
> > honest4$ swift -tc.file tc -sites.file sites.xml psim.basicex1.swift
> > Swift svn swift-r3186 cog-r2572
> > RunID: 20091103-0750-p7z85z61
> > Execution failed:
> > Argument size mismatch. Got 5 names and 0 values
> > RunID: 20091103-0751-sfxthnne
> > Execution failed:
> > RunID: 20091103-0751-oxnhztrc
> > Progress:
> > Execution failed:
> > RunID: 20091103-0751-amtfuvq9
> > Execution failed:
> > Variable not found: path
> > RunID: 20091103-0751-b4sr44x2
> > Execution failed:
> > Ex098
> > org.globus.cog.karajan.workflow.KarajanRuntimeException: Invalid
> > identifier: [$, org.griphyn.vdl.mapping.DataNode identifier tag:benc at ci.uch\
> > icago.edu,2008:swift:dataset:20091103-0751-b65c863d:720000000020 type
> > ProtGeo with no value at dataset=structure path=[1] (not closed)]
> > at
> > org.globus.cog.karajan.util.TypeUtil.toIdentifier(TypeUtil.java:286)
> > at java.lang.Thread.run(Thread.java:595)
> > honest4$
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
