[Fwd: Re: [Swift-devel] Problems with Swift trunk on abe]
Michael Wilde
wilde at mcs.anl.gov
Tue Nov 3 10:19:47 CST 2009
Similar problems happen on Ranger. I used an older Swift build
initially, and it ran.
Then I updated to the latest, and I get the following similar failure:
RunID: 20091103-1016-khfn59yf
Progress:
Ex098
java.lang.NullPointerException
at
org.globus.cog.karajan.workflow.nodes.functions.Variable.function(Variable.java:38)
at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:45)
at
org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:51)
edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:643)
at
edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:668)
at java.lang.Thread.run(Thread.java:619)
Execution failed:
Argument size mismatch. Got 1 names and 2 values
login3$
Im going try the bgp next. If it works there, we can leave this issue
for after SC. Else, I'll need to resolve it.
- Mike
-------- Original Message --------
Subject: Re: [Swift-devel] Problems with Swift trunk on abe
Date: Tue, 03 Nov 2009 08:18:55 -0600
To: swift-devel <swift-devel at ci.uchicago.edu>
References: <4AF03842.70300 at mcs.anl.gov>
Using the Swift build (and swift.properties) that works on communicado,
I still get the same failures on Abe.
I'm going to try a few other systems to see if the problem is widespread
or local to Abe.
- Mike
On 11/3/09 8:03 AM, Michael Wilde wrote:
> What seems like the a build of the same Swift & CoG svn revision is
> working on communicado but giving strange and transient results on Abe.
> A series of 5 runs of the same code (with .xml and .kml files left in
> place) give the set of errors below.
> I will try to use the release build on communicado, to see if this is
> being caused by some Java compiler difference on Abe.
> Suggestions welcome. Mihael, I can get you the logs - they are on abe in
> ~wilde/run.58, along with the source: psim.basicex1.swift
> - Mike
> Output with a few progress and blank lines removed:
> (full output is in: http://www.ci.uchicago.edu/~wilde/abe.swiftproblem.txt )
> honest4$ ls
> Protein.map* Protein.map~* etc input@ logs/ psim.basicex1.swift*
> sites.xml t.swift* t.swift~* tc tc~
> honest4$ swift -tc.file tc -sites.file sites.xml psim.basicex1.swift
> Swift svn swift-r3186 cog-r2572
> RunID: 20091103-0750-p7z85z61
> Execution failed:
> Argument size mismatch. Got 5 names and 0 values
> RunID: 20091103-0751-sfxthnne
> Execution failed:
> RunID: 20091103-0751-oxnhztrc
> Progress:
> Execution failed:
> RunID: 20091103-0751-amtfuvq9
> Execution failed:
> Variable not found: path
> RunID: 20091103-0751-b4sr44x2
> Execution failed:
> Ex098
> org.globus.cog.karajan.workflow.KarajanRuntimeException: Invalid
> identifier: [$, org.griphyn.vdl.mapping.DataNode identifier tag:benc at ci.uch\
> icago.edu,2008:swift:dataset:20091103-0751-b65c863d:720000000020 type
> ProtGeo with no value at dataset=structure path=[1] (not closed)]
> at
> org.globus.cog.karajan.util.TypeUtil.toIdentifier(TypeUtil.java:286)
> at java.lang.Thread.run(Thread.java:595)
> honest4$
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
