[Swift-devel] block allocation
    Zhao Zhang
    zhaozhang at uchicago.edu
    Wed May 27 18:10:21 CDT 2009
Sorry, Mihael, I didn't get your last question.
zhao
Mihael Hategan wrote:
>>>>> On Wed, 2009-05-27 at 16:31 -0500, Zhao Zhang wrote:
>>>>>> Hi, Mihael
>>>>>> I did a clean run of 100 scip jobs on ranger. (scip is a new application
>>>>>> from MCS).
>>>>> And?
>>>> I need your help to make sure coaster is working as expected.
>>> Did the workflow finish successfully? I'll assume "yes", since you
>>> didn't mention any errors, but it would be useful to state such things
>>> from the start.
>> Yes, it was successful.
> That's not a bad sign.
>>> As far as it working as expected, I have more confidence in the workings
>>> of the algorithm itself than in the ancillary stuff. In other words, if
>>> you don't see errors/restarted jobs or stack traces in the logs, it's
>>> likely that things are fine.
>>>>>> The log is at /home/zzhang/scip/ranger-logs/coasters.log
>>>>> [hategan at communicado ~]$ less /home/zzhang/scip/ranger-logs/coasters.log
>>>>> /home/zzhang/scip/ranger-logs/coasters.log: Permission denied
>>>> try now.
>>> [hategan at communicado ~]$ date
>>> Wed May 27 17:26:51 CDT 2009
>> sorry, try again.
> Looks ok. There are some things that should probably be adjusted there,
> but it looks reasonable. Where the queued/running jobs removed from the
> queue when the workflow finished?
