[Swift-devel] block allocation
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed May 27 17:43:30 CDT 2009
On Wed, 2009-05-27 at 17:33 -0500, Zhao Zhang wrote:
> Mihael Hategan wrote:
> >>> On Wed, 2009-05-27 at 16:31 -0500, Zhao Zhang wrote:
> >>>> Hi, Mihael
> >>>> I did a clean run of 100 scip jobs on ranger. (scip is a new application
> >>>> from MCS).
> >>> And?
> >> I need your help to make sure coaster is working as expected.
> > Did the workflow finish successfully? I'll assume "yes", since you
> > didn't mention any errors, but it would be useful to state such things
> > from the start.
> Yes, it was successful.
That's not a bad sign.
> > As far as it working as expected, I have more confidence in the workings
> > of the algorithm itself than in the ancillary stuff. In other words, if
> > you don't see errors/restarted jobs or stack traces in the logs, it's
> > likely that things are fine.
> >>>> The log is at /home/zzhang/scip/ranger-logs/coasters.log
> >>> [hategan at communicado ~]$ less /home/zzhang/scip/ranger-logs/coasters.log
> >>> /home/zzhang/scip/ranger-logs/coasters.log: Permission denied
> >> try now.
> > [hategan at communicado ~]$ date
> > Wed May 27 17:26:51 CDT 2009
> sorry, try again.
Looks ok. There are some things that should probably be adjusted there,
but it looks reasonable. Where the queued/running jobs removed from the
queue when the workflow finished?
