[Swift-devel] block allocation
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon May 25 11:01:22 CDT 2009
On Mon, 2009-05-25 at 10:54 -0500, Mihael Hategan wrote:
> On Mon, 2009-05-25 at 13:30 +0000, Ben Clifford wrote:
> > On Sun, 24 May 2009, Mihael Hategan wrote:
> > > - I updated the documentation on the profile entries, but there are
> > > permission problems when I try to deploy it.
> > hmm. The docs should be updatable by anyone in the vdl2-svn unix group,
> > which you are in.
> > Please can you make a trivial change and then send me the error message?
> I see that the single-page is updated. The problem is with the
> multi-page.
Actually, I'm still unsure about that. Aren't the changes supposed to be
visible immediately after the ./update.sh? If they are, then that, at
least as the userguide is concerned (in particular the single-page),
does not work.
