[Swift-devel] Tool for TeraGrid site info
    Glen Hocky
    hockyg at uchicago.edu
    Wed May 13 14:04:18 CDT 2009
yes that is what it does...i was just lazy but there are other better
ways, certainly
Michael Wilde wrote:
> Glen, I re-read your mail and realize maybe I misunderstood. When you
> said "my script downloads their tool for querying info.teragrid" did
> you mean that tgsites first dynamically downloads the tg info tool,
> and then runs it, unmodified?
> If so, that seems perhaps not the best technical solution, but as long
> as the tg tool is not placed into svn and is not redistributed by us,
> using it by downloading seems to me to not have any licensing issues,
> and I would go ahead and start with whatever is working as the base
> version to build on and improve.
> - Mike
> On 5/13/09 1:48 PM, Michael Wilde wrote:
>> I think its best if we do not copy the tg tool. I dont think there
>> are any licensing issue with using the tg sites info tool, but
>> certainly are issues with putting it into the swift source tree and
>> hence re-distributing it. We definitely do not want to do the latter.
>> Dependencies on the format of the tool we should live with, and adapt
>> our code as needed.  I think we want to use, e.g., the REST
>> interface, which I would hope they either seldom change, or they
>> attempt to keep changes to it backwards compatible.
>> - Mike
>> On 5/13/09 1:33 PM, Glen Hocky wrote:
>>> I'm ok with contributing my code. One thing to note though is rather
>>> than using the info as posted on info.teragrid, my script downloads
>>> their tool for querying info.teragrid. I did this because I was
>>> hoping that their tool would keep a uniform formatting whereas the
>>> back-end might change.
>>> There could however be licensing issues with this usage of their
>>> tool....
>>>> On 5/13/09 12:44 PM, skenny at uchicago.edu wrote:
>>>>> hey ben,
>>>>> we are looking at using glen's code as a starting point for a
>>>>> tool that could be included in swift/committed to swift's svn.
>>>>> there will need to be quite a bit of testing first as i'm
>>>>> unsure about committing someone else's code 'as is'
>>>> If Glen agrees to contribute the code (by signing the license),
>>>> then I think you should commit his exact code as the initial
>>>> revision, and edit from there.
>>>> - Mike
>>>> ...however,
>>>>> my other question regarding this is that there is apparently
>>>>> some *paperwork* involved in this process which would require
>>>>> me (and glen?) to sign some sort of globus licensing agreement
>>>>> i'm unsure of the specifics but could you let me know the best
>>>>> way to get the ball rolling?
>>>>> thanks
>>>>> ~sarah
>>>>> ---- Original message ----
>>>>>> Date: Wed, 29 Apr 2009 11:10:14 -0500
>>>>>> From: Michael Wilde <wilde at mcs.anl.gov>  Subject: [Swift-devel]
>>>>>> Tool for TeraGrid site info  To: Glen Hocky
>>>>>> <hockyg at uchicago.edu>, swift-devel
>>>>> <swift-devel at ci.uchicago.edu>
>>>>>> Glen, where is the latest version of your TG sites info tool?
>>>>>> Ben, what should we do to start testing that, making it
>>>>> uniform with the
>>>>>> osg tool, and make it available for comments and heading towards
>>>>>> inclusion in Swift?
>>>>>> (I think this was commented on earlier - I will track down
>>>>> when I get
>>>>>> back to the planning list in a few days from now)
>>>>>> _______________________________________________
>>>>>> Swift-devel mailing list
>>>>>> Swift-devel at ci.uchicago.edu
>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
