[Swift-devel] Tool for TeraGrid site info
    Michael Wilde
    wilde at mcs.anl.gov
    Wed May 13 13:59:46 CDT 2009
Glen, I re-read your mail and realize maybe I misunderstood. When you
said "my script downloads their tool for querying info.teragrid" did you
mean that tgsites first dynamically downloads the tg info tool, and then
runs it, unmodified?
If so, that seems perhaps not the best technical solution, but as long
as the tg tool is not placed into svn and is not redistributed by us,
using it by downloading seems to me to not have any licensing issues,
and I would go ahead and start with whatever is working as the base
version to build on and improve.
- Mike
On 5/13/09 1:48 PM, Michael Wilde wrote:
> I think its best if we do not copy the tg tool. I dont think there are
> any licensing issue with using the tg sites info tool, but certainly are
> issues with putting it into the swift source tree and hence
> re-distributing it. We definitely do not want to do the latter.
> Dependencies on the format of the tool we should live with, and adapt
> our code as needed.  I think we want to use, e.g., the REST interface,
> which I would hope they either seldom change, or they attempt to keep
> changes to it backwards compatible.
> - Mike
> On 5/13/09 1:33 PM, Glen Hocky wrote:
>> I'm ok with contributing my code. One thing to note though is rather
>> than using the info as posted on info.teragrid, my script downloads
>> their tool for querying info.teragrid. I did this because I was hoping
>> that their tool would keep a uniform formatting whereas the back-end
>> might change.
>> There could however be licensing issues with this usage of their tool....
>>> On 5/13/09 12:44 PM, skenny at uchicago.edu wrote:
>>>> hey ben,
>>>> we are looking at using glen's code as a starting point for a
>>>> tool that could be included in swift/committed to swift's svn.
>>>> there will need to be quite a bit of testing first as i'm
>>>> unsure about committing someone else's code 'as is'
>>> If Glen agrees to contribute the code (by signing the license), then
>>> I think you should commit his exact code as the initial revision, and
>>> edit from there.
>>> - Mike
>>> ...however,
>>>> my other question regarding this is that there is apparently
>>>> some *paperwork* involved in this process which would require
>>>> me (and glen?) to sign some sort of globus licensing agreement
>>>> i'm unsure of the specifics but could you let me know the best
>>>> way to get the ball rolling?
>>>> thanks
>>>> ~sarah
>>>> ---- Original message ----
>>>>> Date: Wed, 29 Apr 2009 11:10:14 -0500
>>>>> From: Michael Wilde <wilde at mcs.anl.gov>  Subject: [Swift-devel]
>>>>> Tool for TeraGrid site info  To: Glen Hocky <hockyg at uchicago.edu>,
>>>>> swift-devel
>>>> <swift-devel at ci.uchicago.edu>
>>>>> Glen, where is the latest version of your TG sites info tool?
>>>>> Ben, what should we do to start testing that, making it
>>>> uniform with the
>>>>> osg tool, and make it available for comments and heading towards
>>>>> inclusion in Swift?
>>>>> (I think this was commented on earlier - I will track down
>>>> when I get
>>>>> back to the planning list in a few days from now)
>>>>> _______________________________________________
>>>>> Swift-devel mailing list
>>>>> Swift-devel at ci.uchicago.edu
>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
