[Swift-devel] Error in Coaster test on Clemson-IT site
    Ben Clifford
    benc at hawaga.org.uk
    Wed May 13 12:40:15 CDT 2009
OK. But try with plain swift + gt2, using a <jobmanager> element in the
sites file. No condor-g, no coasters.
On Wed, 13 May 2009, Zhao Zhang wrote:
> ok, I ran the same test case with condor-g, it failed.
> [zzhang at tp-grid1 sites]$ ./run-site condor-g_back/CLEMSON-IT.xml
> testing site configuration: condor-g_back/CLEMSON-IT.xml
> Removing files from previous runs
> Running test 061-cattwo at Wed May 13 11:14:31 CDT 2009
> Swift svn swift-r2896 cog-r2392
> RunID: 20090513-1114-0tvjyz67
> Progress:  uninitialized:1
> Progress:  Stage in:1
> Progress:  Submitting:1
> Progress:  Submitted:1
> Progress:  Active:1
> Progress:  Active:1
> Progress:  Active:1
> Progress: Failed but can retry:1
> Failed to transfer wrapper log from 061-cattwo-20090513-1114-0tvjyz67/info/6
> on CLEMSON-IT
> Progress:  Active:1
> Progress:  Active:1
> Progress:  Checking status:1
> Failed to transfer wrapper log from 061-cattwo-20090513-1114-0tvjyz67/info/8
> on CLEMSON-IT
> Progress:  Active:1
> Progress:  Active:1
> Progress:  Active:1
> Failed to transfer wrapper log from 061-cattwo-20090513-1114-0tvjyz67/info/a
> on CLEMSON-IT
> Progress:  Failed:1
> Execution failed:
>        Exception in cat:
> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
> Host: CLEMSON-IT
> Directory: 061-cattwo-20090513-1114-0tvjyz67/jobs/a/cat-as69oqaj
> stderr.txt:
> stdout.txt:
> Caused by:
>        No status file was found. Check the shared filesystem on CLEMSON-IT
> Ben Clifford wrote:
> > I meant to also make a sites file for Swift that does not use coasters. That
> > will find some problems that I think the below tests will not find.
> > > Ah, yes, I ran them, here are the results.
> > > [zzhang at tp-grid1 coaster_test]$ globus-job-run osggate.clemson.edu
> > > /usr/bin/id
> > > uid=145767(osg) gid=10000(cuuser) groups=10000(cuuser)
> > > osggate.clemson.edu/jobmanager-condor /usr/bin/id
> > > uid=145767(osg) gid=94175(osg) groups=94175(osg)
> > > [zzhang at tp-grid1 sites]$ globus-url-copy
> > > gsiftp://osggate.clemson.edu/home/osg/logs_clemson.tar
> > > file://`pwd`/logs_clemson.tar
> > > So both globus-job-run and globus-url-copy are working.
> > > zhao
> > > Ben Clifford wrote:
> > > > When you tests these sites with coasters, and they fail, it would be
> > > > useful
> > > > perhaps to also test them without coasters and report if that works.
> > > > This
> > > > also gives more testing for the non-coaster case generally.
> > > > > Hi, Mihael
> > > > > I got a error returned for the language-behavior test on Clemson-IT
> > > > > site
> > > > > with
> > > > > coaster.
> > > > > All gram logs are at
> > > > > /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/logs_clemson.
> > > > > Could you help on checking that error there is.
> > > > > sites.xml
> > > > > [zzhang at tp-grid1 sites]$ cat coaster_test/CLEMSON-IT.xml
> > > > > <config>
> > > > >  <!-- CLEMSON-IT -->
> > > > >  <pool handle="CLEMSON-IT" >
> > > > >    <gridftp  url="gsiftp://osggate.clemson.edu/" />
> > > > >    <execution  provider="coaster" url="osggate.clemson.edu"
> > > > > jobManager="gt2:gt2:condor"/>
> > > > >    <workdirectory >/scratch/data/osg/tmp/CLEMSON-IT</workdirectory>
> > > > >  </pool>
> > > > > </config>
> > > > > Here is the stdout:
> > > > > testing site configuration: coaster_test/CLEMSON-IT.xml
> > > > > Running test 061-cattwo at Wed May 13 10:27:04 CDT 2009
> > > > > RunID: 20090513-1027-d406ke07
> > > > > Progress:
> > > > > Progress:  Active:1
> > > > > 061-cattwo-20090513-1027-d406ke07/info/u
> > > > > on CLEMSON-IT
> > > > > Progress:  Active:1
> > > > > 061-cattwo-20090513-1027-d406ke07/info/x
> > > > > on CLEMSON-IT
> > > > > Progress:  Active:1
> > > > > 061-cattwo-20090513-1027-d406ke07/info/z
> > > > > on CLEMSON-IT
> > > > > Progress:  Failed:1
> > > > > Execution failed:
> > > > >        Exception in cat:
> > > > > Host: CLEMSON-IT
> > > > > Directory: 061-cattwo-20090513-1027-d406ke07/jobs/z/cat-zsqcmqaj
> > > > > stderr.txt:
> > > > > stdout.txt:
> > > > > Caused by:
> > > > >        Failed to start worker: Worker ended prematurely
> > > > > Cleaning up...
> > > > > Shutting down service at https://130.127.11.89:43784
> > > > > Got channel MetaChannel: 1707082587 -> GSSSChannel-null(1)
> > > > > - Done
> > > > > SWIFT RETURN CODE NON-ZERO - test 061-cattwo
> > > > > zhao
> > > > > _______________________________________________
> > > > > Swift-devel mailing list
> > > > > Swift-devel at ci.uchicago.edu
> > > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
