[Swift-devel] Error in Coaster test on Clemson-IT site
Zhao Zhang
zhaozhang at uchicago.edu
Wed May 13 13:09:26 CDT 2009
Hi, Ben
I rerun it with the following sites.xml, it still failed
<config>
<!-- CLEMSON-IT -->
<pool handle="CLEMSON-IT" >
<gridftp url="gsiftp://osggate.clemson.edu/" />
<jobmanager universe="vanilla"
url="osggate.clemson.edu/jobmanager-condor" \
major="2" minor="2" patch="4" />
<workdirectory >/scratch/data/osg/tmp/CLEMSON-IT</workdirectory>
</pool>h
</config>
[zzhang at tp-grid1 sites]$ ./run-site regular/CLEMSON-IT.xml
testing site configuration: regular/CLEMSON-IT.xml
Removing files from previous runs
Running test 061-cattwo at Wed May 13 13:06:51 CDT 2009
Swift svn swift-r2896 cog-r2392
RunID: 20090513-1306-yiec15sd
Progress:
Progress: Stage in:1
Progress: Submitting:1
Progress: Submitted:1
Progress: Active:1
Failed to transfer wrapper log from
061-cattwo-20090513-1306-yiec15sd/info/g on CLEMSON-IT
Progress: Active:1
061-cattwo-20090513-1306-yiec15sd/info/i on CLEMSON-IT
Progress: Active:1
061-cattwo-20090513-1306-yiec15sd/info/k on CLEMSON-IT
Progress: Failed:1
Execution failed:
Exception in cat:
Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
Host: CLEMSON-IT
Directory: 061-cattwo-20090513-1306-yiec15sd/jobs/k/cat-k8dqsqaj
stderr.txt:
stdout.txt:
Caused by:
No status file was found. Check the shared filesystem on CLEMSON-IT
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
Ben Clifford wrote:
> OK. But try with plain swift + gt2, using a <jobmanager> element in the
> sites file. No condor-g, no coasters.
> On Wed, 13 May 2009, Zhao Zhang wrote:
>> ok, I ran the same test case with condor-g, it failed.
>> [zzhang at tp-grid1 sites]$ ./run-site condor-g_back/CLEMSON-IT.xml
>> testing site configuration: condor-g_back/CLEMSON-IT.xml
>> Running test 061-cattwo at Wed May 13 11:14:31 CDT 2009
>> RunID: 20090513-1114-0tvjyz67
>> Progress: uninitialized:1
>> Progress: Active:1
>> Progress: Active:1
>> Progress: Active:1
>> Progress: Failed but can retry:1
>> Failed to transfer wrapper log from 061-cattwo-20090513-1114-0tvjyz67/info/6
>> on CLEMSON-IT
>> Progress: Active:1
>> Progress: Active:1
>> Progress: Checking status:1
>> Failed to transfer wrapper log from 061-cattwo-20090513-1114-0tvjyz67/info/8
>> on CLEMSON-IT
>> Progress: Active:1
>> Progress: Active:1
>> Progress: Active:1
>> Failed to transfer wrapper log from 061-cattwo-20090513-1114-0tvjyz67/info/a
>> on CLEMSON-IT
>> Progress: Failed:1
>> Execution failed:
>> Exception in cat:
>> Host: CLEMSON-IT
>> Directory: 061-cattwo-20090513-1114-0tvjyz67/jobs/a/cat-as69oqaj
>> stderr.txt:
>> stdout.txt:
>> Caused by:
>> Ben Clifford wrote:
>>> I meant to also make a sites file for Swift that does not use coasters. That
>>> will find some problems that I think the below tests will not find.
>>>> Ah, yes, I ran them, here are the results.
>>>> [zzhang at tp-grid1 coaster_test]$ globus-job-run osggate.clemson.edu
>>>> /usr/bin/id
>>>> uid=145767(osg) gid=10000(cuuser) groups=10000(cuuser)
>>>> osggate.clemson.edu/jobmanager-condor /usr/bin/id
>>>> uid=145767(osg) gid=94175(osg) groups=94175(osg)
>>>> [zzhang at tp-grid1 sites]$ globus-url-copy
>>>> gsiftp://osggate.clemson.edu/home/osg/logs_clemson.tar
>>>> file://`pwd`/logs_clemson.tar
>>>> So both globus-job-run and globus-url-copy are working.
>>>> zhao
>>>> Ben Clifford wrote:
>>>>> When you tests these sites with coasters, and they fail, it would be
>>>>> useful
>>>>> perhaps to also test them without coasters and report if that works.
>>>>> This
>>>>> also gives more testing for the non-coaster case generally.
>>>>>> Hi, Mihael
>>>>>> I got a error returned for the language-behavior test on Clemson-IT
>>>>>> site
>>>>>> with
>>>>>> coaster.
>>>>>> All gram logs are at
>>>>>> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/logs_clemson.
>>>>>> Could you help on checking that error there is.
>>>>>> sites.xml
>>>>>> [zzhang at tp-grid1 sites]$ cat coaster_test/CLEMSON-IT.xml
>>>>>> <config>
>>>>>> <!-- CLEMSON-IT -->
>>>>>> <execution provider="coaster" url="osggate.clemson.edu"
>>>>>> jobManager="gt2:gt2:condor"/>
>>>>>> </pool>
>>>>>> </config>
>>>>>> Here is the stdout:
>>>>>> testing site configuration: coaster_test/CLEMSON-IT.xml
>>>>>> Running test 061-cattwo at Wed May 13 10:27:04 CDT 2009
>>>>>> RunID: 20090513-1027-d406ke07
>>>>>> Progress:
>>>>>> Progress: Active:1
>>>>>> 061-cattwo-20090513-1027-d406ke07/info/u
>>>>>> on CLEMSON-IT
>>>>>> Progress: Active:1
>>>>>> 061-cattwo-20090513-1027-d406ke07/info/x
>>>>>> on CLEMSON-IT
>>>>>> Progress: Active:1
>>>>>> 061-cattwo-20090513-1027-d406ke07/info/z
>>>>>> on CLEMSON-IT
>>>>>> Progress: Failed:1
>>>>>> Execution failed:
>>>>>> Exception in cat:
>>>>>> Host: CLEMSON-IT
>>>>>> Directory: 061-cattwo-20090513-1027-d406ke07/jobs/z/cat-zsqcmqaj
>>>>>> stderr.txt:
>>>>>> stdout.txt:
>>>>>> Caused by:
>>>>>> Failed to start worker: Worker ended prematurely
>>>>>> Cleaning up...
>>>>>> Shutting down service at https://130.127.11.89:43784
>>>>>> Got channel MetaChannel: 1707082587 -> GSSSChannel-null(1)
>>>>>> - Done
>>>>>> zhao
>>>>>> _______________________________________________
>>>>>> Swift-devel mailing list
>>>>>> Swift-devel at ci.uchicago.edu
>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
