[Swift-devel] Error in Coaster test on Clemson-IT site
    Zhao Zhang
    zhaozhang at uchicago.edu
    Wed May 13 12:38:20 CDT 2009
ok, I ran the same test case with condor-g, it failed.
[zzhang at tp-grid1 sites]$ ./run-site condor-g_back/CLEMSON-IT.xml
testing site configuration: condor-g_back/CLEMSON-IT.xml
Removing files from previous runs
Running test 061-cattwo at Wed May 13 11:14:31 CDT 2009
Swift svn swift-r2896 cog-r2392
RunID: 20090513-1114-0tvjyz67
Progress:  uninitialized:1
Progress:  Stage in:1
Progress:  Submitting:1
Progress:  Submitted:1
Progress:  Active:1
Progress:  Active:1
Progress:  Active:1
Progress: Failed but can retry:1
Failed to transfer wrapper log from
061-cattwo-20090513-1114-0tvjyz67/info/6 on CLEMSON-IT
Progress:  Active:1
Progress:  Active:1
Progress:  Checking status:1
061-cattwo-20090513-1114-0tvjyz67/info/8 on CLEMSON-IT
Progress:  Active:1
Progress:  Active:1
Progress:  Active:1
061-cattwo-20090513-1114-0tvjyz67/info/a on CLEMSON-IT
Progress:  Failed:1
Execution failed:
        Exception in cat:
Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
Host: CLEMSON-IT
Directory: 061-cattwo-20090513-1114-0tvjyz67/jobs/a/cat-as69oqaj
stderr.txt:
stdout.txt:
Caused by:
        No status file was found. Check the shared filesystem on CLEMSON-IT
Ben Clifford wrote:
> I meant to also make a sites file for Swift that does not use coasters.
> That will find some problems that I think the below tests will not find.
> On Wed, 13 May 2009, Zhao Zhang wrote:
>> Ah, yes, I ran them, here are the results.
>> [zzhang at tp-grid1 coaster_test]$ globus-job-run osggate.clemson.edu /usr/bin/id
>> uid=145767(osg) gid=10000(cuuser) groups=10000(cuuser)
>> osggate.clemson.edu/jobmanager-condor /usr/bin/id
>> uid=145767(osg) gid=94175(osg) groups=94175(osg)
>> [zzhang at tp-grid1 sites]$ globus-url-copy
>> gsiftp://osggate.clemson.edu/home/osg/logs_clemson.tar
>> file://`pwd`/logs_clemson.tar
>> So both globus-job-run and globus-url-copy are working.
>> zhao
>> Ben Clifford wrote:
>>> When you tests these sites with coasters, and they fail, it would be useful
>>> perhaps to also test them without coasters and report if that works. This
>>> also gives more testing for the non-coaster case generally.
>>>> Hi, Mihael
>>>> I got a error returned for the language-behavior test on Clemson-IT site
>>>> with
>>>> coaster.
>>>> All gram logs are at
>>>> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/logs_clemson.
>>>> Could you help on checking that error there is.
>>>> sites.xml
>>>> [zzhang at tp-grid1 sites]$ cat coaster_test/CLEMSON-IT.xml
>>>> <config>
>>>>  <!-- CLEMSON-IT -->
>>>>  <pool handle="CLEMSON-IT" >
>>>>    <gridftp  url="gsiftp://osggate.clemson.edu/" />
>>>>    <execution  provider="coaster" url="osggate.clemson.edu"
>>>> jobManager="gt2:gt2:condor"/>
>>>>    <workdirectory >/scratch/data/osg/tmp/CLEMSON-IT</workdirectory>
>>>>  </pool>
>>>> </config>
>>>> Here is the stdout:
>>>> testing site configuration: coaster_test/CLEMSON-IT.xml
>>>> Running test 061-cattwo at Wed May 13 10:27:04 CDT 2009
>>>> RunID: 20090513-1027-d406ke07
>>>> Progress:
>>>> Progress:  Active:1
>>>> 061-cattwo-20090513-1027-d406ke07/info/u
>>>> on CLEMSON-IT
>>>> Progress:  Active:1
>>>> 061-cattwo-20090513-1027-d406ke07/info/x
>>>> on CLEMSON-IT
>>>> Progress:  Active:1
>>>> 061-cattwo-20090513-1027-d406ke07/info/z
>>>> on CLEMSON-IT
>>>> Progress:  Failed:1
>>>> Execution failed:
>>>>        Exception in cat:
>>>> Host: CLEMSON-IT
>>>> Directory: 061-cattwo-20090513-1027-d406ke07/jobs/z/cat-zsqcmqaj
>>>> stderr.txt:
>>>> stdout.txt:
>>>> Caused by:
>>>>        Failed to start worker: Worker ended prematurely
>>>> Cleaning up...
>>>> Shutting down service at https://130.127.11.89:43784
>>>> Got channel MetaChannel: 1707082587 -> GSSSChannel-null(1)
>>>> - Done
>>>> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
>>>> zhao
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
