[Swift-devel] Error in Coaster test on Clemson-IT site
    Ben Clifford
    benc at hawaga.org.uk
    Wed May 13 11:11:37 CDT 2009
I meant to also make a sites file for Swift that does not use coasters.
That will find some problems that I think the below tests will not find.
On Wed, 13 May 2009, Zhao Zhang wrote:
> Ah, yes, I ran them, here are the results.
> [zzhang at tp-grid1 coaster_test]$ globus-job-run osggate.clemson.edu /usr/bin/id
> uid=145767(osg) gid=10000(cuuser) groups=10000(cuuser)
> osggate.clemson.edu/jobmanager-condor /usr/bin/id
> uid=145767(osg) gid=94175(osg) groups=94175(osg)
> [zzhang at tp-grid1 sites]$ globus-url-copy
> gsiftp://osggate.clemson.edu/home/osg/logs_clemson.tar
> file://`pwd`/logs_clemson.tar
> So both globus-job-run and globus-url-copy are working.
> zhao
> Ben Clifford wrote:
> > When you tests these sites with coasters, and they fail, it would be useful
> > perhaps to also test them without coasters and report if that works. This
> > also gives more testing for the non-coaster case generally.
> > > Hi, Mihael
> > > I got a error returned for the language-behavior test on Clemson-IT site
> > > with
> > > coaster.
> > > All gram logs are at
> > > /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/logs_clemson.
> > > Could you help on checking that error there is.
> > > sites.xml
> > > [zzhang at tp-grid1 sites]$ cat coaster_test/CLEMSON-IT.xml
> > > <config>
> > >  <!-- CLEMSON-IT -->
> > >  <pool handle="CLEMSON-IT" >
> > >    <gridftp  url="gsiftp://osggate.clemson.edu/" />
> > >    <execution  provider="coaster" url="osggate.clemson.edu"
> > > jobManager="gt2:gt2:condor"/>
> > >    <workdirectory >/scratch/data/osg/tmp/CLEMSON-IT</workdirectory>
> > >  </pool>
> > > </config>
> > > Here is the stdout:
> > > testing site configuration: coaster_test/CLEMSON-IT.xml
> > > Removing files from previous runs
> > > Running test 061-cattwo at Wed May 13 10:27:04 CDT 2009
> > > Swift svn swift-r2896 cog-r2392
> > > RunID: 20090513-1027-d406ke07
> > > Progress:
> > > Progress:  Stage in:1
> > > Progress:  Submitting:1
> > > Progress:  Submitted:1
> > > Progress:  Active:1
> > > Failed to transfer wrapper log from
> > > 061-cattwo-20090513-1027-d406ke07/info/u
> > > on CLEMSON-IT
> > > Progress:  Active:1
> > > 061-cattwo-20090513-1027-d406ke07/info/x
> > > on CLEMSON-IT
> > > Progress:  Active:1
> > > 061-cattwo-20090513-1027-d406ke07/info/z
> > > on CLEMSON-IT
> > > Progress:  Failed:1
> > > Execution failed:
> > >        Exception in cat:
> > > Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
> > > Host: CLEMSON-IT
> > > Directory: 061-cattwo-20090513-1027-d406ke07/jobs/z/cat-zsqcmqaj
> > > stderr.txt:
> > > stdout.txt:
> > > Caused by:
> > >        Failed to start worker: Worker ended prematurely
> > > Cleaning up...
> > > Shutting down service at https://130.127.11.89:43784
> > > Got channel MetaChannel: 1707082587 -> GSSSChannel-null(1)
> > > - Done
> > > SWIFT RETURN CODE NON-ZERO - test 061-cattwo
> > > zhao
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
