[Swift-devel] Error in Coaster test on Clemson-IT site
    Zhao Zhang
    zhaozhang at uchicago.edu
    Wed May 13 11:04:57 CDT 2009
Ah, yes, I ran them, here are the results.
[zzhang at tp-grid1 coaster_test]$ globus-job-run osggate.clemson.edu
/usr/bin/id
uid=145767(osg) gid=10000(cuuser) groups=10000(cuuser)
osggate.clemson.edu/jobmanager-condor /usr/bin/id
uid=145767(osg) gid=94175(osg) groups=94175(osg)
[zzhang at tp-grid1 sites]$ globus-url-copy
gsiftp://osggate.clemson.edu/home/osg/logs_clemson.tar
file://`pwd`/logs_clemson.tar
So both globus-job-run and globus-url-copy are working.
zhao
Ben Clifford wrote:
> When you tests these sites with coasters, and they fail, it would be
> useful perhaps to also test them without coasters and report if that
> works. This also gives more testing for the non-coaster case generally.
> On Wed, 13 May 2009, Zhao Zhang wrote:
>> Hi, Mihael
>> I got a error returned for the language-behavior test on Clemson-IT site with
>> coaster.
>> All gram logs are at
>> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/logs_clemson.
>> Could you help on checking that error there is.
>> sites.xml
>> [zzhang at tp-grid1 sites]$ cat coaster_test/CLEMSON-IT.xml
>> <config>
>>  <!-- CLEMSON-IT -->
>>  <pool handle="CLEMSON-IT" >
>>    <gridftp  url="gsiftp://osggate.clemson.edu/" />
>>    <execution  provider="coaster" url="osggate.clemson.edu"
>> jobManager="gt2:gt2:condor"/>
>>    <workdirectory >/scratch/data/osg/tmp/CLEMSON-IT</workdirectory>
>>  </pool>
>> </config>
>> Here is the stdout:
>> testing site configuration: coaster_test/CLEMSON-IT.xml
>> Removing files from previous runs
>> Running test 061-cattwo at Wed May 13 10:27:04 CDT 2009
>> Swift svn swift-r2896 cog-r2392
>> RunID: 20090513-1027-d406ke07
>> Progress:
>> Progress:  Stage in:1
>> Progress:  Submitting:1
>> Progress:  Submitted:1
>> Progress:  Active:1
>> Failed to transfer wrapper log from 061-cattwo-20090513-1027-d406ke07/info/u
>> on CLEMSON-IT
>> Progress:  Active:1
>> Failed to transfer wrapper log from 061-cattwo-20090513-1027-d406ke07/info/x
>> on CLEMSON-IT
>> Progress:  Active:1
>> Failed to transfer wrapper log from 061-cattwo-20090513-1027-d406ke07/info/z
>> on CLEMSON-IT
>> Progress:  Failed:1
>> Execution failed:
>>        Exception in cat:
>> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
>> Host: CLEMSON-IT
>> Directory: 061-cattwo-20090513-1027-d406ke07/jobs/z/cat-zsqcmqaj
>> stderr.txt:
>> stdout.txt:
>> Caused by:
>>        Failed to start worker: Worker ended prematurely
>> Cleaning up...
>> Shutting down service at https://130.127.11.89:43784
>> Got channel MetaChannel: 1707082587 -> GSSSChannel-null(1)
>> - Done
>> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
>> zhao
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
