[Swift-devel] Error in Coaster test on Clemson-IT site
    Ben Clifford
    benc at hawaga.org.uk
    Wed May 13 11:01:25 CDT 2009
When you tests these sites with coasters, and they fail, it would be
useful perhaps to also test them without coasters and report if that
works. This also gives more testing for the non-coaster case generally.
On Wed, 13 May 2009, Zhao Zhang wrote:
> Hi, Mihael
> I got a error returned for the language-behavior test on Clemson-IT site with
> coaster.
> All gram logs are at
> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/logs_clemson.
> Could you help on checking that error there is.
> sites.xml
> [zzhang at tp-grid1 sites]$ cat coaster_test/CLEMSON-IT.xml
> <config>
>  <!-- CLEMSON-IT -->
>  <pool handle="CLEMSON-IT" >
>    <gridftp  url="gsiftp://osggate.clemson.edu/" />
>    <execution  provider="coaster" url="osggate.clemson.edu"
> jobManager="gt2:gt2:condor"/>
>    <workdirectory >/scratch/data/osg/tmp/CLEMSON-IT</workdirectory>
>  </pool>
> </config>
> Here is the stdout:
> testing site configuration: coaster_test/CLEMSON-IT.xml
> Removing files from previous runs
> Running test 061-cattwo at Wed May 13 10:27:04 CDT 2009
> Swift svn swift-r2896 cog-r2392
> RunID: 20090513-1027-d406ke07
> Progress:
> Progress:  Stage in:1
> Progress:  Submitting:1
> Progress:  Submitted:1
> Progress:  Active:1
> Failed to transfer wrapper log from 061-cattwo-20090513-1027-d406ke07/info/u
> on CLEMSON-IT
> Progress:  Active:1
> Failed to transfer wrapper log from 061-cattwo-20090513-1027-d406ke07/info/x
> on CLEMSON-IT
> Progress:  Active:1
> Failed to transfer wrapper log from 061-cattwo-20090513-1027-d406ke07/info/z
> on CLEMSON-IT
> Progress:  Failed:1
> Execution failed:
>        Exception in cat:
> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
> Host: CLEMSON-IT
> Directory: 061-cattwo-20090513-1027-d406ke07/jobs/z/cat-zsqcmqaj
> stderr.txt:
> stdout.txt:
> Caused by:
>        Failed to start worker: Worker ended prematurely
> Cleaning up...
> Shutting down service at https://130.127.11.89:43784
> Got channel MetaChannel: 1707082587 -> GSSSChannel-null(1)
> - Done
> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
> zhao
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
