[Swift-devel] Error in Coaster test on Clemson-IT site
    Zhao Zhang
    zhaozhang at uchicago.edu
    Wed May 13 10:59:10 CDT 2009
Hi, Mihael
I got a error returned for the language-behavior test on Clemson-IT site
with coaster.
All gram logs are at
/home/zzhang/swift_coaster/cog/modules/swift/tests/sites/logs_clemson.
Could you help on checking that error there is.
sites.xml
[zzhang at tp-grid1 sites]$ cat coaster_test/CLEMSON-IT.xml
<config>
  <!-- CLEMSON-IT -->
  <pool handle="CLEMSON-IT" >
    <gridftp  url="gsiftp://osggate.clemson.edu/" />
    <execution  provider="coaster" url="osggate.clemson.edu"
jobManager="gt2:gt2:condor"/>
    <workdirectory >/scratch/data/osg/tmp/CLEMSON-IT</workdirectory>
  </pool>
</config>
Here is the stdout:
testing site configuration: coaster_test/CLEMSON-IT.xml
Removing files from previous runs
Running test 061-cattwo at Wed May 13 10:27:04 CDT 2009
Swift svn swift-r2896 cog-r2392
RunID: 20090513-1027-d406ke07
Progress:
Progress:  Stage in:1
Progress:  Submitting:1
Progress:  Submitted:1
Progress:  Active:1
Failed to transfer wrapper log from
061-cattwo-20090513-1027-d406ke07/info/u on CLEMSON-IT
Progress:  Active:1
061-cattwo-20090513-1027-d406ke07/info/x on CLEMSON-IT
Progress:  Active:1
061-cattwo-20090513-1027-d406ke07/info/z on CLEMSON-IT
Progress:  Failed:1
Execution failed:
        Exception in cat:
Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
Host: CLEMSON-IT
Directory: 061-cattwo-20090513-1027-d406ke07/jobs/z/cat-zsqcmqaj
stderr.txt:
stdout.txt:
Caused by:
        Failed to start worker: Worker ended prematurely
Cleaning up...
Shutting down service at https://130.127.11.89:43784
Got channel MetaChannel: 1707082587 -> GSSSChannel-null(1)
- Done
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
zhao
