[Swift-devel] Another issue regarding uj-pbs-gram2.xml
    Zhao Zhang
    zhaozhang at uchicago.edu
    Mon May  4 15:07:14 CDT 2009
This one?
/home/zzhang/swift_coaster/cog/modules/swift/tests/sites/gram_job_mgr_18272.log
zhao
Mihael Hategan wrote:
> On Mon, 2009-05-04 at 15:02 -0500, Zhao Zhang wrote:
>> I also pulled out the coaster log in the same directory. Then what shall
>> we do with this error?
> Was that the only gram log? What I suspect is that there is another gram
> log which is more relevant.
>> zhao
>>> On Mon, 2009-05-04 at 14:46 -0500, Zhao Zhang wrote:
>>>> Ha, I got it.
>>>> It is at CI network:
>>>> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/gram_job_mgr_22265.log
>>> There you go :)
>>> I'm not sure this is the right log though. This is the one from the job
>>> that was used to start the coaster service, and it shows a different
>>> error (155 - stageout failure).
