[Swift-devel] Another issue regarding uj-pbs-gram2.xml
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon May  4 15:25:32 CDT 2009
On Mon, 2009-05-04 at 15:07 -0500, Zhao Zhang wrote:
> This one?
> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/gram_job_mgr_18272.log
Nope. I suggest copying them all, and I'll look for the right one.
> zhao
> Mihael Hategan wrote:
> > On Mon, 2009-05-04 at 15:02 -0500, Zhao Zhang wrote:
> >> I also pulled out the coaster log in the same directory. Then what shall
> >> we do with this error?
> > Was that the only gram log? What I suspect is that there is another gram
> > log which is more relevant.
> >> zhao
> >>> On Mon, 2009-05-04 at 14:46 -0500, Zhao Zhang wrote:
> >>>> Ha, I got it.
> >>>> It is at CI network:
> >>>> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/gram_job_mgr_22265.log
> >>> There you go :)
> >>> I'm not sure this is the right log though. This is the one from the job
> >>> that was used to start the coaster service, and it shows a different
> >>> error (155 - stageout failure).
