[Swift-devel] Another issue regarding uj-pbs-gram2.xml
Mihael Hategan
hategan at mcs.anl.gov
Mon May 4 15:07:40 CDT 2009
On Mon, 2009-05-04 at 15:02 -0500, Zhao Zhang wrote:
> I also pulled out the coaster log in the same directory. Then what shall
> we do with this error?
Was that the only gram log? What I suspect is that there is another gram
log which is more relevant.
> zhao
> Mihael Hategan wrote:
> > On Mon, 2009-05-04 at 14:46 -0500, Zhao Zhang wrote:
> >> Ha, I got it.
> >> It is at CI network:
> >> /home/zzhang/swift_coaster/cog/modules/swift/tests/sites/gram_job_mgr_22265.log
> > There you go :)
> > I'm not sure this is the right log though. This is the one from the job
> > that was used to start the coaster service, and it shows a different
> > error (155 - stageout failure).
