[Swift-devel] Another issue regarding uj-pbs-gram2.xml
    Zhao Zhang
    zhaozhang at uchicago.edu
    Mon May  4 14:29:57 CDT 2009
Hi, Mihael
I could not login that machine by neither ssh nor gsissh.
[zzhang at communicado sites]$ ssh osg-ce.grid.uj.ac.za
ssh: connect to host osg-ce.grid.uj.ac.za port 22: Connection refused
[zzhang at communicado sites]$ gsissh osg-ce.grid.uj.ac.za
zhao
Mihael Hategan wrote:
> Can you retrieve the relevant gram log (it's on the remote site, in your
> home directory, named gram*.log)?
> On Mon, 2009-05-04 at 14:03 -0500, Zhao Zhang wrote:
>> Hi, Ben
>> The coaster test on uj-pbs-gram2.xml failed due to the following reason.
>> I am also attaching the result from "globus-job-run" and "uj-pbs-gram2.xml".
>> Any idea why it is happening? Thanks.
>> zhao
>> [zzhang at communicado sites]$ ./run-site coaster/uj-pbs-gram2.xml
>> testing site configuration: coaster/uj-pbs-gram2.xml
>> Removing files from previous runs
>> Running test 061-cattwo at Mon May 4 13:57:42 CDT 2009
>> Swift 0.9rc2 swift-r2860 cog-r2388
>> RunID: 20090504-1357-43geyd0c
>> Progress:
>> Progress:  Stage in:1
>> Progress:  Submitting:1
>> Progress:  Submitted:1
>> Progress:  Active:1
>> Failed to transfer wrapper log from
>> 061-cattwo-20090504-1357-43geyd0c/info/v on teraport
>> Progress:  Active:1
>> Progress: Failed but can retry:1
>> 061-cattwo-20090504-1357-43geyd0c/info/y on teraport
>> Progress:  Active:1
>> 061-cattwo-20090504-1357-43geyd0c/info/0 on teraport
>> Progress:  Failed:1
>> Execution failed:
>>         Exception in cat:
>> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
>> Host: teraport
>> Directory: 061-cattwo-20090504-1357-43geyd0c/jobs/0/cat-0k2l2caj
>> stderr.txt:
>> stdout.txt:
>> Caused by:
>>         Failed to start worker:
>> null
>> null
>> org.globus.gram.GramException: The job failed when the job manager
>> attempted to run it
>>         at
>> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
>>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>>         at org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>>         at java.lang.Thread.run(Thread.java:595)
>> Cleaning up...
>> Shutting down service at https://152.106.18.251:34054
>> Got channel MetaChannel: 12128247 -> GSSSChannel-null(1)
>> - Done
>> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
>> [zzhang at communicado sites]$ globus-job-run osg-ce.grid.uj.ac.za /usr/bin/id
>> uid=640(osgedu) gid=2000(osg) groups=2000(osg)
>> <config>
>>   <pool handle="teraport" >
>>     <gridftp  url="gsiftp://osg-ce.grid.uj.ac.za" />
>>     <execution provider="coaster" url="osg-ce.grid.uj.ac.za"
>> jobManager="gt2:gt2:pbs" />
>>     <workdirectory >/nfs/home/benc/swifttest</workdirectory>
>>     <profile namespace="karajan" key="jobThrottle">4</profile>
>>   </pool>
>> </config>
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
