[Swift-devel] Another issue regarding uj-pbs-gram2.xml
    Ben Clifford
    benc at hawaga.org.uk
    Mon May  4 14:34:35 CDT 2009
On Mon, 4 May 2009, Zhao Zhang wrote:
> I could not login that machine by neither ssh nor gsissh.
no-one apart from special people can ssh into that machine - in general,
most OSG machines will not let you log in interactively.
You should be able to use globus-job-run and globus-url-copy to list and
copy files from that machine to your own machine, though.
> [zzhang at communicado sites]$ ssh osg-ce.grid.uj.ac.za
> ssh: connect to host osg-ce.grid.uj.ac.za port 22: Connection refused
> [zzhang at communicado sites]$ gsissh osg-ce.grid.uj.ac.za
> zhao
> Mihael Hategan wrote:
> > Can you retrieve the relevant gram log (it's on the remote site, in your
> > home directory, named gram*.log)?
> > On Mon, 2009-05-04 at 14:03 -0500, Zhao Zhang wrote:
> > > Hi, Ben
> > > The coaster test on uj-pbs-gram2.xml failed due to the following reason.
> > > I am also attaching the result from "globus-job-run" and
> > > "uj-pbs-gram2.xml".
> > > Any idea why it is happening? Thanks.
> > > zhao
> > > [zzhang at communicado sites]$ ./run-site coaster/uj-pbs-gram2.xml
> > > testing site configuration: coaster/uj-pbs-gram2.xml
> > > Removing files from previous runs
> > > Running test 061-cattwo at Mon May 4 13:57:42 CDT 2009
> > > Swift 0.9rc2 swift-r2860 cog-r2388
> > > RunID: 20090504-1357-43geyd0c
> > > Progress:
> > > Progress:  Stage in:1
> > > Progress:  Submitting:1
> > > Progress:  Submitted:1
> > > Progress:  Active:1
> > > Failed to transfer wrapper log from
> > > 061-cattwo-20090504-1357-43geyd0c/info/v on teraport
> > > Progress:  Active:1
> > > Progress: Failed but can retry:1
> > > 061-cattwo-20090504-1357-43geyd0c/info/y on teraport
> > > Progress:  Active:1
> > > 061-cattwo-20090504-1357-43geyd0c/info/0 on teraport
> > > Progress:  Failed:1
> > > Execution failed:
> > >         Exception in cat:
> > > Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
> > > Host: teraport
> > > Directory: 061-cattwo-20090504-1357-43geyd0c/jobs/0/cat-0k2l2caj
> > > stderr.txt:
> > > stdout.txt:
> > > Caused by:
> > >         Failed to start worker:
> > > null
> > > null
> > > org.globus.gram.GramException: The job failed when the job manager
> > > attempted to run it
> > >         at
> > > org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
> > >         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
> > >         at
> > > org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
> > >         at java.lang.Thread.run(Thread.java:595)
> > > Cleaning up...
> > > Shutting down service at https://152.106.18.251:34054
> > > Got channel MetaChannel: 12128247 -> GSSSChannel-null(1)
> > > - Done
> > > SWIFT RETURN CODE NON-ZERO - test 061-cattwo
> > > [zzhang at communicado sites]$ globus-job-run osg-ce.grid.uj.ac.za
> > > /usr/bin/id
> > > uid=640(osgedu) gid=2000(osg) groups=2000(osg)
> > > <config>
> > >   <pool handle="teraport" >
> > >     <gridftp  url="gsiftp://osg-ce.grid.uj.ac.za" />
> > >     <execution provider="coaster" url="osg-ce.grid.uj.ac.za"
> > > jobManager="gt2:gt2:pbs" />
> > >     <workdirectory >/nfs/home/benc/swifttest</workdirectory>
> > >     <profile namespace="karajan" key="jobThrottle">4</profile>
> > >   </pool>
> > > </config>
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
