[Swift-devel] Another issue regarding uj-pbs-gram2.xml
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon May  4 14:25:13 CDT 2009
Can you retrieve the relevant gram log (it's on the remote site, in your
home directory, named gram*.log)?
On Mon, 2009-05-04 at 14:03 -0500, Zhao Zhang wrote:
> Hi, Ben
> The coaster test on uj-pbs-gram2.xml failed due to the following reason.
> I am also attaching the result from "globus-job-run" and "uj-pbs-gram2.xml".
> Any idea why it is happening? Thanks.
> zhao
> [zzhang at communicado sites]$ ./run-site coaster/uj-pbs-gram2.xml
> testing site configuration: coaster/uj-pbs-gram2.xml
> Removing files from previous runs
> Running test 061-cattwo at Mon May 4 13:57:42 CDT 2009
> Swift 0.9rc2 swift-r2860 cog-r2388
> RunID: 20090504-1357-43geyd0c
> Progress:
> Progress:  Stage in:1
> Progress:  Submitting:1
> Progress:  Submitted:1
> Progress:  Active:1
> Failed to transfer wrapper log from
> 061-cattwo-20090504-1357-43geyd0c/info/v on teraport
> Progress:  Active:1
> Progress: Failed but can retry:1
> 061-cattwo-20090504-1357-43geyd0c/info/y on teraport
> Progress:  Active:1
> 061-cattwo-20090504-1357-43geyd0c/info/0 on teraport
> Progress:  Failed:1
> Execution failed:
>         Exception in cat:
> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
> Host: teraport
> Directory: 061-cattwo-20090504-1357-43geyd0c/jobs/0/cat-0k2l2caj
> stderr.txt:
> stdout.txt:
> Caused by:
>         Failed to start worker:
> null
> null
> org.globus.gram.GramException: The job failed when the job manager
> attempted to run it
>         at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>         at org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>         at java.lang.Thread.run(Thread.java:595)
> Cleaning up...
> Shutting down service at https://152.106.18.251:34054
> Got channel MetaChannel: 12128247 -> GSSSChannel-null(1)
> - Done
> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
> [zzhang at communicado sites]$ globus-job-run osg-ce.grid.uj.ac.za /usr/bin/id
> uid=640(osgedu) gid=2000(osg) groups=2000(osg)
> <config>
>   <pool handle="teraport" >
>     <gridftp  url="gsiftp://osg-ce.grid.uj.ac.za" />
>     <execution provider="coaster" url="osg-ce.grid.uj.ac.za"
> jobManager="gt2:gt2:pbs" />
>     <workdirectory >/nfs/home/benc/swifttest</workdirectory>
>     <profile namespace="karajan" key="jobThrottle">4</profile>
>   </pool>
> </config>
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
