[Swift-devel] Another issue regarding uj-pbs-gram2.xml
    Zhao Zhang
    zhaozhang at uchicago.edu
    Mon May  4 14:03:00 CDT 2009
Hi, Ben
The coaster test on uj-pbs-gram2.xml failed due to the following reason.
I am also attaching the result from "globus-job-run" and "uj-pbs-gram2.xml".
Any idea why it is happening? Thanks.
zhao
[zzhang at communicado sites]$ ./run-site coaster/uj-pbs-gram2.xml
testing site configuration: coaster/uj-pbs-gram2.xml
Removing files from previous runs
Running test 061-cattwo at Mon May 4 13:57:42 CDT 2009
Swift 0.9rc2 swift-r2860 cog-r2388
RunID: 20090504-1357-43geyd0c
Progress:
Progress:  Stage in:1
Progress:  Submitting:1
Progress:  Submitted:1
Progress:  Active:1
Failed to transfer wrapper log from
061-cattwo-20090504-1357-43geyd0c/info/v on teraport
Progress:  Active:1
Progress: Failed but can retry:1
061-cattwo-20090504-1357-43geyd0c/info/y on teraport
Progress:  Active:1
061-cattwo-20090504-1357-43geyd0c/info/0 on teraport
Progress:  Failed:1
Execution failed:
        Exception in cat:
Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
Host: teraport
Directory: 061-cattwo-20090504-1357-43geyd0c/jobs/0/cat-0k2l2caj
stderr.txt:
stdout.txt:
Caused by:
        Failed to start worker:
null
null
org.globus.gram.GramException: The job failed when the job manager
attempted to run it
        at
org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
        at org.globus.gram.GramJob.setStatus(GramJob.java:184)
        at org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
        at java.lang.Thread.run(Thread.java:595)
Cleaning up...
Shutting down service at https://152.106.18.251:34054
Got channel MetaChannel: 12128247 -> GSSSChannel-null(1)
- Done
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
[zzhang at communicado sites]$ globus-job-run osg-ce.grid.uj.ac.za /usr/bin/id
uid=640(osgedu) gid=2000(osg) groups=2000(osg)
<config>
  <pool handle="teraport" >
    <gridftp  url="gsiftp://osg-ce.grid.uj.ac.za" />
    <execution provider="coaster" url="osg-ce.grid.uj.ac.za"
jobManager="gt2:gt2:pbs" />
    <workdirectory >/nfs/home/benc/swifttest</workdirectory>
    <profile namespace="karajan" key="jobThrottle">4</profile>
  </pool>
</config>
