[Swift-devel] Re: coaster issue
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri May  1 18:50:22 CDT 2009
On Fri, 2009-05-01 at 17:53 -0500, Zhao Zhang wrote:
> thanks, then I got this
> [zzhang at tp-grid1 sites]$  globus-job-run
> osg-ce.grid.uc.ac.za/jobmanager-pbs /usr/bin/id
.uj. instead of .uc. maybe? Presumably it's not University of
Cohannesburg.
> GRAM Job submission failed because the connection to the server failed
> (check host and port) (error code 12)
> Zhao Zhang wrote:
> > Mihael Hategan wrote:
> >> On Fri, 2009-05-01 at 15:18 -0500, Zhao Zhang wrote:
> >>>>> I found "$TMP Location /nfs/osg-data" on
> >>>>> http://vors.grid.iu.edu/cgi-bin/index.cgi?region=0&VO=24&grid=1&dtype=0&res=387#SITELISTING,
> >>>>> but it still doesn't work. Do you know any dir that I could try out?
> >>>> What exactly did you try (i.e. paste relevant lines from sites.xml).
> >>> I used this one /nfs/osg-data/osgedu/benc/swift
> >> Well, the mighty benc doesn't allow you to write to his directory. Make
> >> your own!
> >>> org.globus.gram.GramException: The job failed when the job manager
> >>> attempted to run it
> >>>         at
> >> Use the globusrun test. Always use the globusrun test!
> > In this way?
> > osg-ce.grid.uj.ac.za:gt2:gt2:pbs /usr/bin/id
> > GRAM Job submission failed because data transfer to the server failed
> > (error code 10)
> > I am not sure if it is the right format to specify the provider.
> > zhao
