[Swift-devel] Re: coaster issue
    Zhao Zhang
    zhaozhang at uchicago.edu
    Fri May  1 17:53:30 CDT 2009
thanks, then I got this
[zzhang at tp-grid1 sites]$  globus-job-run
osg-ce.grid.uc.ac.za/jobmanager-pbs /usr/bin/id
GRAM Job submission failed because the connection to the server failed
(check host and port) (error code 12)
Zhao Zhang wrote:
> Mihael Hategan wrote:
>> On Fri, 2009-05-01 at 15:18 -0500, Zhao Zhang wrote:
>>>>> I found "$TMP Location /nfs/osg-data" on
>>>>> http://vors.grid.iu.edu/cgi-bin/index.cgi?region=0&VO=24&grid=1&dtype=0&res=387#SITELISTING,
>>>>> but it still doesn't work. Do you know any dir that I could try out?
>>>> What exactly did you try (i.e. paste relevant lines from sites.xml).
>>> I used this one /nfs/osg-data/osgedu/benc/swift
>> Well, the mighty benc doesn't allow you to write to his directory. Make
>> your own!
>>> org.globus.gram.GramException: The job failed when the job manager
>>> attempted to run it
>>>         at
>> Use the globusrun test. Always use the globusrun test!
> In this way?
> osg-ce.grid.uj.ac.za:gt2:gt2:pbs /usr/bin/id
> GRAM Job submission failed because data transfer to the server failed
> (error code 10)
> I am not sure if it is the right format to specify the provider.
> zhao
