[Swift-devel] Re: coaster issue
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Fri May  1 17:08:14 CDT 2009
Hi Zhao,
No.  Its  globus-job-run osg-ce.grid.uc.ac.za/jobmanager-pbs /usr/bin/id
Then for gridftp service  tests, checkout uberftp. you can do ls and all
those nice directory poking stuff compared to
file-transfer-operations-only globus-url-copy
-Allan
On Fri, May 01, 2009 at 04:24:52PM -0500, Zhao Zhang wrote:
>> Use the globusrun test. Always use the globusrun test!
> In this way?
> [zzhang at tp-grid1 sites]$ globus-job-run osg-ce.grid.uj.ac.za:gt2:gt2:pbs
> /usr/bin/id
> GRAM Job submission failed because data transfer to the server failed
> (error code 10)
> I am not sure if it is the right format to specify the provider.
> zhao
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
