[Swift-devel] Re: coaster issue
    Zhao Zhang
    zhaozhang at uchicago.edu
    Fri May  1 16:24:52 CDT 2009
Mihael Hategan wrote:
> On Fri, 2009-05-01 at 15:18 -0500, Zhao Zhang wrote:
>>>> I found "$TMP Location /nfs/osg-data" on
>>>> http://vors.grid.iu.edu/cgi-bin/index.cgi?region=0&VO=24&grid=1&dtype=0&res=387#SITELISTING,
>>>> but it still doesn't work. Do you know any dir that I could try out?
>>> What exactly did you try (i.e. paste relevant lines from sites.xml).
>> I used this one /nfs/osg-data/osgedu/benc/swift
> Well, the mighty benc doesn't allow you to write to his directory. Make
> your own!
>> org.globus.gram.GramException: The job failed when the job manager
>> attempted to run it
>>         at
> Use the globusrun test. Always use the globusrun test!
In this way?
[zzhang at tp-grid1 sites]$ globus-job-run osg-ce.grid.uj.ac.za:gt2:gt2:pbs
/usr/bin/id
GRAM Job submission failed because data transfer to the server failed
(error code 10)
I am not sure if it is the right format to specify the provider.
zhao
