[Swift-devel] Re: coaster issue
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri May  1 15:28:43 CDT 2009
On Fri, 2009-05-01 at 15:18 -0500, Zhao Zhang wrote:
> >> I found "$TMP Location /nfs/osg-data" on
> >> http://vors.grid.iu.edu/cgi-bin/index.cgi?region=0&VO=24&grid=1&dtype=0&res=387#SITELISTING,
> >> but it still doesn't work. Do you know any dir that I could try out?
> > What exactly did you try (i.e. paste relevant lines from sites.xml).
> I used this one /nfs/osg-data/osgedu/benc/swift
Well, the mighty benc doesn't allow you to write to his directory. Make
your own!
> org.globus.gram.GramException: The job failed when the job manager
> attempted to run it
>         at
Use the globusrun test. Always use the globusrun test!
