[Swift-devel] Re: coaster issue
    Zhao Zhang
    zhaozhang at uchicago.edu
    Fri May  1 14:57:14 CDT 2009
Mihael Hategan wrote:
> On Fri, 2009-05-01 at 14:21 -0500, Zhao Zhang wrote:
>> Good, Thanks, Mihael. I write it down in my test book, with
>> "error-reason-solution" tuple.
>> Here comes another two:
>> Cannot create directory /nfs/osg-data/osgedu/benc/swift/061-cattwo-20090501-1035-4fpfuxk2
>> 500-System error in mkdir: Permission denied
> I think that's fairly clear. You'll need to find a workdir that you can
> write to.
I found "$TMP Location /nfs/osg-data" on
http://vors.grid.iu.edu/cgi-bin/index.cgi?region=0&VO=24&grid=1&dtype=0&res=387#SITELISTING,
but it still doesn't work. Do you know any dir that I could try out?
>> Caused by:
>> 	Cannot submit job: Could not submit job (qsub reported an exit code of 188). no error output
> I'm sure that means something, but can you try with globus instead of
> the PBS provider?
Changing <execution provider="coaster" url="osg-ce.grid.uj.ac.za"
jobManager="gt2:pbs" />
to <execution provider="coaster" url="osg-ce.grid.uj.ac.za"
jobManager="gt2:gt2" /> ?
zhao
