[Swift-devel] Re: coaster issue
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri May  1 14:44:23 CDT 2009
On Fri, 2009-05-01 at 14:21 -0500, Zhao Zhang wrote:
> Good, Thanks, Mihael. I write it down in my test book, with
> "error-reason-solution" tuple.
> Here comes another two:
> Cannot create directory /nfs/osg-data/osgedu/benc/swift/061-cattwo-20090501-1035-4fpfuxk2
> 500-System error in mkdir: Permission denied
I think that's fairly clear. You'll need to find a workdir that you can
write to.
> Caused by:
> 	Cannot submit job: Could not submit job (qsub reported an exit code of 188). no error output
I'm sure that means something, but can you try with globus instead of
the PBS provider?
