[Swift-devel] Re: coaster issue
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri May  1 15:08:12 CDT 2009
On Fri, 2009-05-01 at 14:57 -0500, Zhao Zhang wrote:
> Mihael Hategan wrote:
> > On Fri, 2009-05-01 at 14:21 -0500, Zhao Zhang wrote:
> >> Good, Thanks, Mihael. I write it down in my test book, with
> >> "error-reason-solution" tuple.
> >> Here comes another two:
> >> Cannot create directory /nfs/osg-data/osgedu/benc/swift/061-cattwo-20090501-1035-4fpfuxk2
> >> 500-System error in mkdir: Permission denied
> > I think that's fairly clear. You'll need to find a workdir that you can
> > write to.
> I found "$TMP Location /nfs/osg-data" on
> http://vors.grid.iu.edu/cgi-bin/index.cgi?region=0&VO=24&grid=1&dtype=0&res=387#SITELISTING,
> but it still doesn't work. Do you know any dir that I could try out?
What exactly did you try (i.e. paste relevant lines from sites.xml).
> >> Caused by:
> >> 	Cannot submit job: Could not submit job (qsub reported an exit code of 188). no error output
> > I'm sure that means something, but can you try with globus instead of
> > the PBS provider?
> Changing <execution provider="coaster" url="osg-ce.grid.uj.ac.za"
> jobManager="gt2:pbs" />
> to <execution provider="coaster" url="osg-ce.grid.uj.ac.za"
> jobManager="gt2:gt2" /> ?
gt2:gt2:pbs.
