[Swift-devel] Re: coaster issue
Zhao Zhang
zhaozhang at uchicago.edu
Fri May 1 14:21:51 CDT 2009
Good, Thanks, Mihael. I write it down in my test book, with
"error-reason-solution" tuple.
Here comes another two:
testing site configuration: coaster/renci-engage-coaster.xml
Removing files from previous runs
Running test 061-cattwo at Fri May 1 10:35:21 CDT 2009
Swift 0.9rc2 swift-r2860 cog-r2388
RunID: 20090501-1035-4fpfuxk2
Progress:
Progress: Initializing site shared directory:1
Execution failed:
Could not initialize shared directory on renci-engage
Caused by:
org.globus.cog.abstraction.impl.file.FileResourceException: Cannot create directory /nfs/osg-data/osgedu/benc/swift/061-cattwo-20090501-1035-4fpfuxk2
Caused by:
Server refused performing the request. Custom message: Server refused creating directory (error code 1) [Nested exception message: Custom message: Unexpected reply: 500-Command failed : globus_gridftp_server_file.c:globus_l_gfs_file_mkdir:554:
500-System error in mkdir: Permission denied
500-A system call failed: Permission denied
500 End.]
SWIFT RETURN CODE NON-ZERO - test 061-cattwo
SITE FAIL! Exit code 1 for site definition coaster/renci-engage-coaster.xml
The globus-job-run is ok for renci.
[zzhang at tp-grid1 ~]$ globus-job-run belhaven-1.renci.org /usr/bin/id
uid=715(osg) gid=715(osg) groups=715(osg)
testing site configuration: coaster/uj-pbs-gram2.xml
Running test 061-cattwo at Fri May 1 10:39:03 CDT 2009
RunID: 20090501-1039-bqzi23df
Progress:
Progress: Stage in:1
Progress: Submitting:1
Progress: Submitted:1
Failed to transfer wrapper log from 061-cattwo-20090501-1039-bqzi23df/info/k on teraport
Progress: Active:1
Progress: Failed but can retry:1
Failed to transfer wrapper log from 061-cattwo-20090501-1039-bqzi23df/info/m on teraport
Failed to transfer wrapper log from 061-cattwo-20090501-1039-bqzi23df/info/o on teraport
Progress: Failed:1
Execution failed:
Exception in cat:
Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
Host: teraport
Directory: 061-cattwo-20090501-1039-bqzi23df/jobs/o/cat-oilxv6aj
stderr.txt:
stdout.txt:
Caused by:
Cannot submit job: Could not submit job (qsub reported an exit code of 188). no error output
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Cannot submit job: Could not submit job (qsub reported an exit code of 188). no error output
at org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:63)
at org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:46)
at org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:43)
at org.globus.cog.abstraction.coaster.service.job.manager.WorkerManager.startWorker(WorkerManager.java:221)
at org.globus.cog.abstraction.coaster.service.job.manager.WorkerManager.run(WorkerManager.java:145)
Caused by: org.globus.cog.abstraction.impl.scheduler.common.ProcessException: Could not submit job (qsub reported an exit code of 188). no error output
at org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.start(AbstractExecutor.java:94)
at org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:53)
... 4 more
Cleaning up...
Shutting down service at https://152.106.18.251:46990
Got channel MetaChannel: 756415799 -> GSSSChannel-null(1)
- Done
SITE FAIL! Exit code 1 for site definition coaster/uj-pbs-gram2.xml
globus-job-run is also ok for this site
[zzhang at tp-grid1 ~]$ globus-job-run osg-ce.grid.uj.ac.za /usr/bin/id
uid=640(osgedu) gid=2000(osg) groups=2000(osg)
zhao
