[Swift-devel] Re: coaster issue
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri May  1 14:15:24 CDT 2009
On Fri, 2009-05-01 at 14:09 -0500, Zhao Zhang wrote:
> No, globus-job-run failed
> ERROR: Failed to connect to local queue manager
> CEDAR:6001:Failed to connect to <128.135.92.83:32796>
> GRAM Job failed because the job failed when the job manager attempted to
> run it (error code 17)
> So, in this case could we tell that it is a GLOBUS issue, which means we
> need to contact the support team?
Yes, and yes.
> zhao
> Mihael Hategan wrote:
> > On Fri, 2009-05-01 at 14:01 -0500, Zhao Zhang wrote:
> >> Hi, Mike
> >> I got an error when I rerun the test with coaster on teraport. Any ideas
> >> for this error?
> > Does a simple globusrun work (make sure it's not a fork job)?
> >> [zzhang at tp-grid1 sites]$ ./run-site
> >> coaster/gwynn-coaster-gram2-gram2-condor.xml
> >> testing site configuration: coaster/gwynn-coaster-gram2-gram2-condor.xml
> >> Removing files from previous runs
> >> Running test 061-cattwo at Fri May 1 13:46:37 CDT 2009
> >> Swift 0.9rc2 swift-r2860 cog-r2388
> >> RunID: 20090501-1346-ge8hz8r7
> >> Progress:
> >> Progress:  Stage in:1
> >> Progress:  Submitting:1
> >> Progress:  Submitted:1
> >> Failed to transfer wrapper log from
> >> 061-cattwo-20090501-1346-ge8hz8r7/info/4 on teraport
> >> Progress:  Active:1
> >> 061-cattwo-20090501-1346-ge8hz8r7/info/6 on teraport
> >> Progress:  Active:1
> >> 061-cattwo-20090501-1346-ge8hz8r7/info/8 on teraport
> >> Progress:  Failed:1
> >> Execution failed:
> >>         Exception in cat:
> >> Arguments: [061-cattwo.1.in, 061-cattwo.2.in]
> >> Host: teraport
> >> Directory: 061-cattwo-20090501-1346-ge8hz8r7/jobs/8/cat-863f47aj
> >> stderr.txt:
> >> stdout.txt:
> >> Caused by:
> >>         Failed to start worker:
> >> null
> >> null
> >> org.globus.gram.GramException: The job failed when the job manager
> >> attempted to run it
> >>         at
> >> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:530)
> >>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
> >>         at org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
> >>         at java.lang.Thread.run(Thread.java:595)
> >> Cleaning up...
> >> Shutting down service at https://128.135.92.83:46035
> >> Got channel MetaChannel: 665483948 -> GSSSChannel-null(1)
> >> - Done
> >> SWIFT RETURN CODE NON-ZERO - test 061-cattwo
> >> zhao
